can someone tell me what these casting # are - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2006, 06:11 PM
heads 3888991 /333882 /14022601 blocks 3978044 /3970010 small block chevy
Old 01-21-2006, 06:23 PM
NOlowrider's Avatar
US Navy-Retired
http://www.mortec.com/castnum.htm
Old 01-21-2006, 09:38 PM
the 333882 heads were used initially on 1970 to 76 smc 400. usually with 194 intake valves. th e 3970010 block is very common and was used for truck and high performance 4 bolt main applications however, there were some that were for two bolt applications...I have one of each. the 882 heads are very prone to cracking so I would have anything purchased used checked out before installing...experience speaking here. I had two sets of 882's now I have one. also the 327 can have the same 3970010 # in 68 and 69 corvette camaro and other high performance applications... that is all the info I have on that ...hope it helps
Old 01-22-2006, 12:01 AM
Any chance that 3978044 could be a roughly cast 3970014?
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
Cylinder head casting number Forsaken502 Engine 5 02-23-2004 07:09 PM
74 heads on a 87 block?? punk1c5040 Engine 22 02-17-2004 09:16 PM
Can't Find Casting Date on 12-bolt PrimaDude Transmission - Rearend 0 03-11-2003 07:25 PM
