Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can SS paint be used to touch up bc/cc
Old 05-25-2011, 01:37 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Originally Posted by Irelands child
Why not pick a hidden spot and try your touch up paint...
I would have to order a whole quart of it if I was to go this route. So I wanted to be quite certain before I go to that expense that the urethane SS is not going to create any problems when used with the urethane BC/CC.
And if I understand you correctly, it shouldn't have any ill effects...with the exception of not matching up absolutely perfect...which is almost always the case when you don't spray on the repair I think.
Always learning...and sharing what I've learned.
