Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can SS paint be used to touch up bc/cc
Old 05-25-2011, 04:46 PM
dinger's Avatar
dinger dinger is offline
Originally Posted by Arrowhead
Why not make your own SS? Try mixing some of your left over base coat and premixed clear (mix your clear and activator first) and whala, you have a single stage touch up paint! Just mix it 1:1 base to clear. I caught that trick from Barryk a few years ago. Now I'm sure you can't do that with every combination of base and clear, but it's worth a try. I've even mixed the base w/ reducer and added the clear concoction to it and sprayed out of an air brush.
This does work and many shops will give you a small bottle for touch-up after a paint job.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
