Can SS paint be used to touch up bc/cc - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2011, 10:28 AM
cboy's Avatar
Last journal entry: Finished
I shot my car with Restoration Shop bc/cc and it has begun to gather some tiny stone chips and other scratches. Restoration Shop also offers the same color paint in a Single Stage Urethane. I'm thinking that would be a better way to touch up the stone chips (applied with pin or tiny brush tip) than to try to shoot bc/cc. Any potential problems mixing the two types of paint?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 05-25-2011, 11:09 AM
Irelands child's Avatar
Don't you just "love" road rash. But you can consider them battle scars
I've only using SS on mine for touch up - but those spots will show (at least to your discerning eye).
Dave W
Old 05-25-2011, 11:59 AM
cboy's Avatar
Originally Posted by Irelands child
...I've only using SS on mine for touch up -
So no "chemical" sorts of issues using SS to repair bc/cc?
Old 05-25-2011, 12:21 PM
Not on the road rash kind of dings, but it is a urethane base paint that I'm using ( or at least it's not lacquer ).
Why not pick a hidden spot and try your touch up paint - i.e. bottom of a door. If that touch up is lacquer based, you might have some lifting - tho it probably isn't.
Old 05-25-2011, 12:37 PM
cboy's Avatar
Why not pick a hidden spot and try your touch up paint...
I would have to order a whole quart of it if I was to go this route. So I wanted to be quite certain before I go to that expense that the urethane SS is not going to create any problems when used with the urethane BC/CC.
And if I understand you correctly, it shouldn't have any ill effects...with the exception of not matching up absolutely perfect...which is almost always the case when you don't spray on the repair I think.
Old 05-25-2011, 01:48 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Why not make your own SS? Try mixing some of your left over base coat and premixed clear (mix your clear and activator first) and whala, you have a single stage touch up paint! Just mix it 1:1 base to clear. I caught that trick from Barryk a few years ago. Now I'm sure you can't do that with every combination of base and clear, but it's worth a try. I've even mixed the base w/ reducer and added the clear concoction to it and sprayed out of an air brush.
Old 05-25-2011, 02:31 PM
cboy's Avatar
Interesting idea, and worth a try.
Old 05-25-2011, 03:45 PM
TucsonJay's Avatar
My paint store suggested I add about 20-25% clear to the base, to make single stage.
Hope that helps to keep it from being too transparent.
Old 05-25-2011, 03:46 PM
dinger's Avatar
This does work and many shops will give you a small bottle for touch-up after a paint job.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 05-25-2011, 06:41 PM
Not a bad idea, George. Too bad I don't have any clear
Dave W
Old 05-26-2011, 06:08 AM
Arrowhead's Avatar
Wiki Edits: 5
Stop over and I'll give you some - I'll trade you for a ride in your hot rod
I'll be off all next week working in the garage so stop by anytime.
Old 05-26-2011, 06:17 AM
.....if the weather holds, I'll make it 'the plan'.
Dave W
Old 05-26-2011, 07:09 AM
cboy's Avatar
Can I come too? After all, I started this thread.
Old 05-26-2011, 07:36 AM
YOU DID? You're right - been known to do a hijack
Well of course you can visit - but ONLY if you drive your creation. Directions are simple - I-90 EAST TO I-87 North to .....well when you get that far, call for local driving directions
Dave W
Old 05-26-2011, 07:52 AM
cboy's Avatar
... Directions are simple - I-90 EAST TO I-87 North to .....
Or in my case it would be: Drive to Chicago. Take a left. And Dave's place is the 7,864th mailbox on the right.
Touch up paint for BC/CC 66 Restomod Body - Exterior 3 03-22-2009 07:59 PM
Touch up paint?? Bluepen Body - Exterior 2 09-12-2007 07:10 AM
Using touch-up paint tubes jray Body - Exterior 2 09-01-2007 11:00 AM
touch up paint work john morales Body - Exterior 1 02-20-2007 08:17 PM
where can i buy touch up paint? sc2dave Body - Exterior 3 06-04-2005 04:24 PM
