Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can a steel rim be made skinnier ?
Old 10-26-2008, 08:31 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Originally Posted by 4.3minor
WEll I need a rim 4.5 inchs wide for the front. That is as wide as I can go. Id like to stay with some nice clean steel rims. The ones I was thinking of using were older Chev truck rallys, but they only come in 6 inch form what I can tell. I dont want to go and order some crazy expensive set of custom made rism for this project.
I called Stockton wheel last week for a quote on a custom made wheel and they charge less than 150.00 per wheel..not really crazy expensive if it solves the problem...
Why so skinny?
Mikey
BE different....ACT normal.
