Can a Torque Converter be Tested? If so How! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2003, 08:39 AM
New Member
1987 GMC Jimmy, thru help from this forum I think I have found that the torque converter on this truck is bad. Is there a way to check a converter to see if it is bad. I guess I mean, is there a way I can test it? Any suggestions or tips are apprecited.
Thanks in Advance
Old 11-01-2003, 11:23 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Best way to do that is take it to a LOCAL tranny shop with old timer owner who can analyze it. Shouldn't cost too much to get a diagnosis. Don't go to AAMCO or a chain like that with slack-jawed mouth-breather employes. They will try to sell you a whole new tranny @ 2xprice.
Old 11-03-2003, 09:50 AM
k2mooch's Avatar
I agree with Willys on that one. AAMCO in Florence, SC suckered me into a rebuild job that I never authorized them to do. Went to court with it too and they threw out the case since I signed a release for them to do what was necessary. THAT was considered a release to do the work even though I specifically told the guy to 'diagnose only'. Anyway, stay away from that AAMCO unless you're getting close enough to throw a brink through the window.
MoocH
