can u down stroke chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2013, 02:37 AM
l want to put a 262 crank which is (3.100) in a 350. what would need to be done to it. I just want something different. Thanks ...ps. it would be like 311cid
Old 01-03-2013, 04:05 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Chuck the block up on the mains and cut the decks to 9.000"
Stack will be 8.975"
Use these pistons....
Speed-Pro Hypereutectic Pistons ZH860CP40 - SummitRacing.com
With these rods.....
Scat Pro Stock I-Beam Connecting Rods 26000P - SummitRacing.com
Use any 64cc head, cut head decks to 62cc...
and bolt 'em on with these gaskets....
Fel-Pro Head Gaskets Q7733SH1 - SummitRacing.com
Static compression ratio will be 9.59:1
Use this Crane solid lifter camshaft....
Excellent low end and midrange torque and HP, fair idle,
moderate performance usage, mild bracket racing, auto
trans w/2500+converter, 2600-3000 cruise RPM, limited
oval track, 8.75 to 10.0 compression ratio advised.
Grind #F-228/3067-2-6 Operating range 2400-6000 rpm's
Cam part number 110911
Lifters part number 99250-16
Springs part number 99846-16
228/238.... 290/300....LSA 106 degrees, IO12, IC36, EO49, EC9
Lash 0.022" HOT
Valve lift 0.460"/0.480"
Dynamic Compression Ratio will be 8.336:1
Squish will be 0.041"
The Following User Says Thank You to techinspector1 For This Useful Post:
fordss (01-03-2013)
Old 01-03-2013, 05:38 AM
vinniekq2's Avatar
.030 bore with 2.9 stroke =296 cubes
use a head that flows 230 plus CFM and a solid roller cam and make 400 hp at 7500 rpm
The Following User Says Thank You to vinniekq2 For This Useful Post:
fordss (01-03-2013)
Old 01-03-2013, 06:21 AM
Carroll Caudle from Amarillo TX, NHRA Div. 4, 1969 U.S. Nationals C/MP Record Holder.
Carroll Caudle's '55 Chevy C/MP Record Holder had a 311 CI screamer and he made it work. In 1968, Caudle designed a 2-4 barrel tunnel ram intake using the lower part of a 1957 Chevrolet fuel-injection manifold. After the 1969 U.S. Nationals, Vic Edelbrock borrowed Caudle's manifold and took it to his facility in California where he copied the design and produced the first tunnel ram intake manifold using a new device Edelbrock called a "flow bench".
Caudle built a SBC engine with 1957 283 CI (3.00 stroke) crank, 5.700" rods, Venolia 12:1 pistons in a 1962 327 Ci +.060" OS (4.060" bore) block for 311 CI.
The Following User Says Thank You to MouseFink For This Useful Post:
fordss (01-03-2013)
Old 01-03-2013, 06:51 AM
Old & Furious
Why not build the 302 with the forged cranks that came stock or with aftermarket. cast crank is good but why not go all the way. the 302 is a proven combo and will make a ton of power. This combo cam stock in a few gm performance cars. Potential was never reached chevy's customers wanted bigger cubes so that is what they were sold. No part of the 302 was really weak or poor performing.
I have herd from several ppl the 302 will turn 9k rpm without scattering. Not sure if that is true but would love to see it.
The Following User Says Thank You to hcompton For This Useful Post:
fordss (01-03-2013)
Old 01-03-2013, 12:46 PM
gearheadslife's Avatar
MentalMuffinMan
Lash 0.022" HOT
this I like..
HAY Tech, nice build..
I wonder what it do if.. you offset ground the crank in reverse of what is normally done to add stroke.. say if the made 30 under rod bearing
and offsetground to take stroke away and see if a 6.0 rod can be shoved in it..
with a 350 bore there should be no lack of compression height pistons to choose from
The Following User Says Thank You to gearheadslife For This Useful Post:
fordss (01-03-2013)
Old 01-03-2013, 12:57 PM
vinniekq2's Avatar
You can buy off the shelf 3 inch ( good quality cranks) 2.9 from callies.There is a tonne of room for a 6 inch rod.
6,000 rpm will make around 350 plus horse power potential and not require great heads except the screw in studs. roller rockers etc are standard equipment for high RPM.CR will need to be 10 ish or better
fordss (01-03-2013)
Old 01-03-2013, 01:20 PM
Senior Curmudgeon
Wiki Edits: 326
I used a 6" rod in the recipe....
Old 01-03-2013, 01:30 PM
MentalMuffinMan
missed that opps..
Old 01-03-2013, 03:31 PM
Carroll Caudle's 311 CI engine had a 1962 327 block, casting #3782870. The 283 crank was #2725236 with 2.30" main and 2.00" rod bearings. The #3782870 blocks were originally equipped with a PowerGlide transmission. The used blocks were cured without excessive main bearing loading.
Carroll Caudle's 311 CID engine produced 600 HP. He left the line at 11,000 RPM and shifted with a BW T-10 4-speed at 8,000 RPM. ET: 11.46
His '55 Chevy had a '57 Olds rear end with 5.86:1 gears. The heads were #3991462 double hump FI heads ported and flow tested by the late Joe Mondello. The engine used a 42 lb. flywheel to prevent bogging on the line. The Vic Edelbrock prototype tunnel ram intake manifold had two AFB 4-barrel carburetors and later he used two Holley 660 CFM carburetors.
NHRA Modified Production class required:
Only a lap belt, stock interior, slapper bars OK, no roll cage, full bumpers, no wheel well cut-outs, no push bars, no engine set-back, stock glass, any transmission, engine and body by the same manufacturer, stock brakes, front shocks. Not following the requirements put you in GAS class.
Those were the days. We removed the front shocks from a 1962 Chevrolet Impala 409/409 to get more front end lift and the NHRA officials at Temple Academy Drag Way near Temple TX moved us from Super Stock to Gas.
fordss (01-03-2013)
Old 01-03-2013, 04:43 PM
ok wow is the answer. I thought you were gonna bust on my balls for being so low of a cubic inch....Appreciate all of your responses. Thanks to everyone.
Old 01-03-2013, 04:55 PM
How fast is fast enough?
one thing no one has mentioned is that there are 383's that go to 9,000 RPM, and the hard part is NOT the stroke but the valvetrain, harmonics, and oiling.
I'm you just want 7,000 RPM a stock 350 crank with 6.125" rods and some light weight pistons is all you need for the rotating assembly, and a solid flat cam with good valvesprings, rockers, and pushrods will hold up most of the valvetrain end. And you can modify a wet sump system to be adequate as well.
Old 01-04-2013, 04:59 AM
For a street driven vehicle, you should run the largest engine possible.
Old 01-04-2013, 06:00 AM
F-BIRD'88's Avatar
Yada Yada Yada
Are looking to have a SBC engine that has a short stroke or really want a small CID SBC that revs high?
peak horsepower and peak torque occur at a high rpm.
Old 01-04-2013, 04:54 PM
Senior Curmudgeon
Wiki Edits: 326
What are you trying to say here? What motor? What cam? What heads?
square bore/stroke and high rod/stroke ratios blight Engine 29 01-19-2012 11:46 AM
std stroke for sbc 350? bwomp969 Engine 3 07-17-2009 01:25 AM
327/350 borex stroke/specs BowTiePride Engine 20 12-10-2008 07:31 PM
How much stroke is too much for block with 350 mains? flyin99 Engine 11 09-25-2007 07:58 AM
short stroke VS long stroke pool brian12c Hotrodding Basics 43 06-07-2005 04:40 PM
