can u help wake the dead?
here is the situation I have a 67 chevy truck that has sat for 2 years we have replaced the carb, cap, rotor, air filter, plugs & wires,changed the fluids, and all filters replaced. There was about a gallon of old gas in the tank we added new fuel along with stabalizer changed the fuel filter and fired it up after adjusting the carb she now runs! although the problem is she is missing She will sit there great on a idle but when you give her any gas she falls right on her face. I have checked and there is plenty of fuel to the carb. Idle adjustment is at 2 turns out to start to keep her running they are at 4 turns out ( quadrajet) What am I missing? this is my first project so please bear with me Amy
Brand new
Sir, this is a brand new carb Q-jet 4bbl getting LOTS of fuel but wont stay running what has me also puzzled is there is not any black smoke coming out the pipes
Sometimes the fuel system will flow enough fuel to start the engine but not enough to keep it running. Also the mechanical fuel pump could be weak. Check for any leak around the vent hole. This would signify a broken diaphram. I really think that is where you will find your problem. |
going to check now on the fuel pump ( filters all got changed ) TY soo much wish me luck
I have nothing to add to this thread that has not already been said. I saw the location listed as Ozarks. Technically, I live in the Ozarks as well. Just down in Arkansas.
I just wanted to say Hi to a neighbor.
Does it behave this way just when the engine is cold or all the time?
What is the ambient temperature in "the ozarks" these days? I'm thinking that you may be dealing with an automatic choke that is set too lean ... especially since it's a new carb. And I totally agree with Choctaw Bob on the fuel trash comments. Do a fuel delivery test ... take the hose off at the carb and extend it with anoher piece of fuel line. Crank the engine and see how long it takes to fill a moonshine botle Sorry ... "Ozarks" ... couldn't resist.
My car starts fine, but it won't idle right unless you give it a little gas. sometimes it takes a half second before I hit the gas before it actually sounds like it's revving. I am thinkin' carb problems. I just rebuild it, but I might have message something up. Maybe a whole new carb, since mine is really old =) If it was the original fomoco carb, then I'd probably stick with it and replace it, but it's not, so that's what's goin' on.
Oh, I forgot to tell you what to do to help yourself out. The spring is different sizes on the two different ends. The big side has to go to the top of the carb, and the little side towards the plunger, so that the arm will operate, and not just be slowly rising by letting the carb linkage push it. |
okay Amy, if your truck has HEI I'm going to throw this out there since everyone has been suggesting fuel problems... I have a '61 chevy pickup that sat for, well two years, anyways it did the same thing. I too concentrated on the fuel; new carb, filters, fuel line, flushed the tank, then went on to new plug wires, cap and rotor. What I finally found (months later) was the little 'banana clip' (this is what I call it; it probably has a name but it is a little banana shaped plastic part with wires plugged into both ends) that sits under the rotor was bad. Now my little truck runs like a top. I don't think these clips go bad from sitting, but I've had a few go out in my time and they always seem to be the last thing I check. Sometimes they can shut an engine down completely, but sometimes they keep it running but doing weird things. Might be worth a check.
| Wake Up!!!! | akm | Off-Topic | 83 | 04-26-2009 07:42 AM |
| '79 TA dead | GearHead69 | Electrical | 2 | 06-03-2005 04:11 PM |
| i need some help. battery keeps going dead. | 406 ss monte | Electrical | 1 | 05-31-2005 01:56 AM |
| my dad came back from the dead today. | bullheimer | Hotrodders' Lounge | 9 | 05-28-2004 12:10 PM |
| 1980 corvette battery keeps going dead? | Aboveknee | Electrical | 5 | 01-23-2004 03:56 PM |
