can u put hei Distributor on ls1 & vortec engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2012, 12:08 AM
like the older chevy to put carb on it .. what would i need to do this other than intake & carb . ..... stuff i can buy off ebay ...THANKS
Old 12-23-2012, 08:07 AM
SSedan64's Avatar
LS1 = No
96-99 or so Vortec = Yes
Old 12-23-2012, 05:57 PM
can u just change the intake and drop in the older hei in it or is the more to do? thanks
Old 12-23-2012, 06:20 PM
you need a vortec specific intake, then any hei will drop in.
you can also add one to an ls series engine. you will need a different timing cover built for doing that, a bolt on gear for the front of the cam, and then they run a ford distrib up front like a ford.
a nice option for the ls is a kit you can buy that includes an edelbrock carb intake and an msd controller that picks up off the stock cam and crank sensors, and fires the stock coil packs. pretty reasonably priced for what you get.
Old 12-23-2012, 09:16 PM
Okay thanks
Old 12-24-2012, 08:04 AM
Banned
Okay thanks
As always, the biggest question is- WHY?
It's like swapping out a new Boss DOHC 5.0L engine for a flat head Ford.
Old 12-24-2012, 07:18 PM
i just dont like efi only like carb engine lol
Old 12-24-2012, 08:12 PM
Banned
you can control the ignition independently from the fuel.
Old 12-24-2012, 09:18 PM
i just like old set up than the newer one
DUI Distributor & 1970 Cadillac engine Coodeville Engine 4 01-02-2010 04:02 PM
Put the engine back together and wont start..Distributor? 1970Chevy Engine 11 10-11-2007 11:08 PM
Pulled HEI out,put old points distributor back in, no fire namdlo Electrical 1 08-13-2004 01:19 AM
New user, LS1/6 Engine & PCM tuning guy.. gen3perf Engine 3 01-30-2004 05:04 PM
B&M supercharger/HEI distributor? Marcus Engine 2 12-13-2002 08:50 PM
