LinkBack | Thread Tools |
Nope i was wrong holley 750 dp uses drilled plates not notched ones. Drilled should be fine for the way the idle circuit works.
You are correct with the drilled plates. Sorry had to research the carb to find out. Didnt want to talk out my arse. |
Okay, I checked the vacuum can plugged into full manifold. It's adding 8* at idle and ~14* all in.
18* initial 36* total WITH VACUUM 26* initial ~50* total I thought the vacuum can should be giving all of it's advance at idle. Anyone else think it's weird that both distributors I bought for this engine came preset for 18* mechanical advance? And if it did, why isn't the vacuum can also preset for low vacuum situations? Am I doing something completely wrong? Here is the dizzy I have now. |
Like when coming to a stop or something that can lower the idle, if the idle falls down to ~500, it struggles to bring itself back up to ~1000 (where I have it set to idle). It seems like, with full manifold on the vacuum can, the car is depending on that vacuum advance to stay alive, and when something (like brake booster) drains the limited vacuum that turns the vacuum advance to zero, causing the idle to struggle to come back up and turn the vacuum advance back on and then idle correctly. Also, let me re-state to be clear: WITHOUT VACUUM: 18* initial, 36* total. WITH VACUUM: 26* initial, ~50* total. That means the vacuum is adding ~8* at idle, and ~14* over 3k rpm. Isn't a vacuum advance can supposed to be giving it's full advance at idle? |
What is the duration of the cam?, what is the vacuum level at crusie speed? get a gage for the inside of the car, extend the hose or what ever, what is the starting point of movement of rod travel in "hg vacuum of the cansiter? what is the end point of rod travel in "hg? Set it to start to move at 3-4 "hg, get it to stop moving at 7-8 "hg, limit the added advance to 12-14 at the crank. If it is not adjustable get one that is, crane or accel maybe MSD. |
Got any pix of the dizzy with the cap off. Showing the vacum adavnce and wieghts. I might be able to help. Also any parts you have left over it says it comes with the recurve kit. Should be a bunch springs and parts.
Zerocyde,
Just my two cents. Try disconnecting the vacuum adv. and plugging the carb port, and take it for a short test drive. Keep it short because it will be retarded somewhat. Make sure its allready hot before the test. If the bucking/surging stops you know its probably too much advance from vacuum can. Then get a vacuum limiter plate that Crane sells and install it, and try limiting your vac. adv. as someone else suggested. Its a pretty cheap test that you can get rid of if you don't like it. You'll also be able to use it later after you change your gears to optimize your mileage. You can also use it with a adj. vac. can. Usually a good sign of too much vac. adv. is surging when deccelarating. Forgive the spelling. What happened to the spell checker? I'd leave it connected to ported vac in you current tune IMO. FWIW ssmonty |
There is lockout for Mechanical advance and vacum advance. Both need to be set very restrictive and go for more initial.
You can close off the vacum line and setup with out vacum advance and see if it will help smooth things out better. Just to get the hole vac can system out of the equation and see if it needs to be tuned. It may turn out to not effect the lope at all. |
yes the range is set with an allen key via a set screw through the hose nipple opening, some have it some dont, I think the size is 3/32 or there abouts. |
| Duraspark distributor mechanical advance issue | isaac338 | Engine | 20 | 07-13-2012 06:49 PM |
| Tuning MSD Mechanical Advance Distributor | hotrod937 | Engine | 7 | 05-13-2011 11:48 AM |
| mechanical or vacuum advance | 65ELCMO | Engine | 7 | 05-27-2010 10:37 PM |
| Vacuum Vs. mechanical advance | stinky jinx | Engine | 7 | 11-02-2004 11:09 AM |
| what first? advance curve or carb tuning? | dirtydave | Engine | 3 | 11-07-2003 04:42 PM |
