Can Vinyl be shrunk?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2004, 08:38 PM
76IMP's Avatar
New Member
i have a bench seat for my 76 imp that got knocked on the floor (it was leaning against the wall) it landed on a brick... well, it was stored in my back garage so i didn't notice it until now. It didn't rip the seat but it left a impaled it, leaving a BAD spot... so can this be repaired, and if so... could i perform it??? any replys would be very helpful, thanks Ian
Old 04-23-2004, 05:12 AM
poncho62's Avatar
Wiki Edits: 5
It should return back to its original shape on its own....How long since you removed the brick?
A warm blast from a hair dryer might help. I would leave it for a few days 1st and see what happens.
Ontario Rodders
Old 05-18-2004, 10:10 PM
Vesimies's Avatar
New Member
ya, i'd leave it for a few days too - if it's still not coming out, give it a quick shot with a heat gun - just till it's getting hot (do not melt it) then lay something cold over it (I use an aluminum block that has been stored in the freezer - for the flat areas but a bag of frozen peas will do just the same)
