Can VolksWagens be Hot Rodded? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2007, 04:02 PM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
My Grandfather has 3 VolksWagens that are sitting in a field of broomstraw rotting away. the side skirts are starting to fall off so its getting a good bit of rust damage. I want to know is it worth the effort to drag at least one of them out and try to make a racer out of it? I've seen the episode of PINKS where they raced the beetle and wanted to know was it realistic for an ametur to try it. My grandfather was a VW mechanic so i know he could answer my tech questions but is it worth it or should i leave them a rotting.
I also have had an offer to clean out my VW stash of the 3 for a trade to a 1965 Mustang Coupe which need a new interior or a 1997 240sx with a nissan RD28DDT engine(skyline engine)..
i'd rather have the mustang b/c eventhough its not a GT .. it still would be neat.
and if i'm not mistaken with alot of work couldnt it be transformed to a GT?
which option should i stick with?
-Scott
Old 01-08-2007, 04:09 PM
65Stanger's Avatar
Check the water, check the oil
6 Cylinder 1965 Mustang?! GET IT! www.fordsix.com will be your next stop! Make a real fast 6er. You'll have a great time with that mustang, learn more than you ever though, have fun re-doing the upholstery, and have fun getting looks everywhere you go. =))) You'll like the mustang more than anything else you listed, guaranteed. I wouldn't waste my time on rotting VWs, but if that's what you want to do, then I would suggest you go that route. Still though, for my money, get the pony!!!
Old 01-08-2007, 04:44 PM
poncho62's Avatar
Wiki Edits: 5
The Mustang is worth more than the 3 VWs............It is a more basic car also, so parts wont be as hard to find or as expensive. I think you will be happier with it in the long run.
That said, VWs are fun to work on too.
Old 01-08-2007, 07:10 PM
I tend to agree. But if the Mustang has a six and a manual transmission, be aware that the trans is extremely weak and won't take anything remotely resembling abuse. Mine was on its 13th overhaul when it got T-boned to death at 28,000 miles. My mother even tore it up once.
I also like VW's, but you'll find hotrod parts are not exactly cheap, and the amount of money it would take to make it actually fast would be exorbitant, at best. But for a cheap, easy-to-work-on, dependable driver, they can't be beat. And you have parts cars if you need them. If you decide to mess with them, get a copy of John Muir's book "How to Keep Your Volkswagen Alive", preferably the oldest version you can find. Your grandfather may know of the book, but if not, he'll surely get a few laughs out of it.
Old 01-08-2007, 07:23 PM
You can do so many things with VW's I would at least do someting with them, I have been considering doing a hotrod project like one of these.
http://www.vwtrendsweb.com/features/...agen_hot_rods/
http://www.vwtrendsweb.com/features/.../photo_09.html
Jordon
Old 01-08-2007, 08:00 PM
tab's Avatar
tab tab is offline
So you have a choice between a 65 Stang and some junk Vdubs? If you can't figure this one out on your own, you shouldn't be posting here...
But to answer your question: YES, a Vdub can be a rockin 1/4 miler. Way back when in Detroit there was a 9 sec Volks running a 4cyl Volks engine. He musta put mucho $$$$$ into it though to get it to run like that.
Old 01-08-2007, 08:26 PM
Army Strong
haha
i know i should be thinking straight..
but i think the V dubs would be cool flyin down the track
but i'd get alot more looks from blower stickin out a 428 CJ on a Mustang Coupe.
haha
so i guess i am pretty stupid...
but i was convinced right after i posted that by reading some threads on here
thanks
-scott
Old 01-08-2007, 09:15 PM
54truck's Avatar
Crazier By The Minute
I have had both
If the bottom is not rusted out of the Mustang,take it. I have owned/driven both 65 Mustangs and several 1970's Beetles. The money put into a Mustang will be better spent in my opinion. Bud
Old 01-08-2007, 09:24 PM
cboy's Avatar
Last journal entry: Finished
Sure VW's can be hot rodded. He's my C/A from the mid 70's. SBC, tunnel ram, and a clutch turbo all sitting in a Chapman Chassis with a gutted VW shell slung over the top. There's a gazillion Mustangs out there. But 11 second bugs...now those are pretty rare. And yes that's me in the second shot...filling the radiator between runs.
Always learning...and sharing what I've learned.
Old 01-08-2007, 09:27 PM
redlightning's Avatar
I found this video of a VW and Mustang racing.
http://video.google.com/videoplay?do...=wheelie&hl=en
Old 01-08-2007, 10:00 PM
cboy's Avatar
Here's another rodded bug. I was parked next to this guy at Back to the Fifties a couple years ago.
Old 01-09-2007, 07:05 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
VW bug engines are great to learn on. They are more like motorcycle engines than Detroit iron though. They aren't that expensive to build, not taking everything into consideration. Instead of having to tank and bore the block, then fit pistons and rings, you buy replacement cylinders complete with pistons and rings (sometimes even installed) and bolt them on. The only limit to engine size is how big someone makes these "jugs". Compare building to a traditional four and the costs will be about the same.
You don't need any heavy machine tools to work on a VW engine either. It's line bored with a special boring bar powered by a heavy duty 1/2" drill. you can pull the engine with the help of a buddy and/or a floor jack. They are great to learn mechanics on. Limited in power, but less limited than other four cylinders out there. You can't compare it to a V-8, but it has more power potential than the 200 inch Ford six -- mostly due to limiting factors of the Ford design.
Why does the guy want to trade the Mustang? I'd look it over real good before deciding. Floors and the cowl (which likely leaks -- that's common) can be replaced easy enough, but make sure there's no major chassis damage. The support ("frame") rails can be replaced, but that's a lot of work! The running boards and floors of the bug are pretty easy to replace. Nearly everything on the bug is easy to work on/replace -- it was designed to be repaired by small shops easily. I can't think of many other cars that were designed from the start to be easy to repair. Most are designed to be easy to manufacture, repair is secondary. Dr. Porsche designed the bug for both (Yes, THAT Dr. Ferdinand Porsche, of sports car fame).
Old 01-09-2007, 12:16 PM
Flipper_1938's Avatar
Here's mine. I bought it for $100. Spent about another $150 to rebuild the engine, $325 for drop spindles & disc brakes, another $75 for new master cylinder and all rubber brake lines.
I think it is a cool in-town beater.
Old 01-09-2007, 12:19 PM
Here's mine. Lowered a little. The front suspension was narrowed 5" to get the tires in the right spot.
$100 VW + a little shop time.
Old 01-09-2007, 12:50 PM
JJ350's Avatar
It's amazing how cool a car can look with the right stance...
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Hot rod builders wanted- Western N.C. WoodsEdge Hotrodders' Lounge 16 11-13-2013 01:47 PM
Beverly Hillbillies Hot Rod tgotcha Hotrodders' Lounge 14 06-29-2010 06:09 PM
Hot wire and fuse on aux. fan switch rapsag Electrical 13 06-23-2006 08:36 AM
How hot is too hot? henkelphoto Engine 9 06-05-2006 05:04 PM
