can yo uburn threw clearcoat with 1500-2000 wet sandpaper - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2007, 07:57 PM
can you burn threw clearcoat with 1500-2000 wet sandpaper
i definatly dont want to burn threw after searching this forum it seems as if many people burn threw the clear and have to start over again, i dont mind putting the extra work in with 1500wet, will it save me from burning threw?
Old 03-20-2007, 08:14 PM
302 Z28's Avatar
Yes, you most certainly can burn through with 1500 or 2000.
Please use the spell checker when you post.
Thank You
Vince
Old 03-20-2007, 08:19 PM
You want three good coats of clear applied if you're planning on doing any serious color sanding. With two coats of clear you wouldn't want to be very aggressive. Remember even if you don't burn through you still need an adequate amount of clear on the surface to protect the basecoat from UV damage. For a show car finish many painters will apply three coats of clear then give it a thorough sanding with a block followed by two-three flow coats of clear then a colorsand and buff.
Old 03-20-2007, 08:38 PM
Thank You
Vince
there, do you feel better?
Old 03-21-2007, 05:05 AM
roger1's Avatar
Thank You
Vince
One of the things I like about the new Firefox 2.0 Browser is that it underlines a misspelled word right when it is typed. Then you right click on the word and choices come up for words that you can choose from. It is making me lazy about thinking about the spelling the words. But my posts will have no misspellings.
I recommend Firefox 2.0 it is great.
Roger
Old 03-21-2007, 05:56 AM
302 Z28's Avatar
Yes, I'm threw now.
Vince
Old 03-21-2007, 06:54 AM
Mabee mor peepil shud pracktiz the lost artt uv pruuf reeding
Old 03-21-2007, 07:01 AM
roger1's Avatar
Sounds like good advice Bob.
If you barely went thru the clear in a few places in the first color sand, would you be OK because you are putting more clear on with the flow coats?
