Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - can yo uburn threw clearcoat with 1500-2000 wet sandpaper
Old 03-20-2007, 08:19 PM
baddbob baddbob is offline
You want three good coats of clear applied if you're planning on doing any serious color sanding. With two coats of clear you wouldn't want to be very aggressive. Remember even if you don't burn through you still need an adequate amount of clear on the surface to protect the basecoat from UV damage. For a show car finish many painters will apply three coats of clear then give it a thorough sanding with a block followed by two-three flow coats of clear then a colorsand and buff.
