Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - can you convert diesel engine to gas ?
Old 10-05-2012, 11:32 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
why would you consider doing it? even if something as simple as compression change worked,what about the different cam timing and different fuel metering. Diesel engines are designed to work at 3000 rpms or lower,generally speaking
The Following User Says Thank You to vinniekq2 For This Useful Post:
fordss (10-08-2012)
