can you convert diesel engine to gas ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-08-2012, 05:31 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Originally Posted by fordss View Post
ok what engine head would fit ? thanks for your help
None that I am aware of.
You may be able to lower the compression by changing pistons or something ... ???
The Following User Says Thank You to 66GMC For This Useful Post:
fordss (10-08-2012)
  #17 (permalink)
Old 10-08-2012, 05:45 PM
ok ill just try it see what happen some day .. thanks
  #18 (permalink)
Old 10-08-2012, 08:36 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
You could use a crank driven distributor? I gotta think when you are all said and done, you'll have a small fortune in this compared to an engine swap.
But, it's all good from here in the peanut gallery.
  #19 (permalink)
Old 10-09-2012, 07:20 AM
One of the things required for a diesel engine to operate is high compression to ignite the fuel charge as it uses no spark plugs. Running gasoline will require drastically reducing the compression by either shortening the stroke or replacing the heads with heads with a massive combustion chambers. Because of the high compression diesels usually have a stronger bottom end than a gasoline engine. It is possible to convert a diesel to gas, but I strongly doubt that it is worth the time and effort. Stay with the diesel and add massive turbochargers, propane injection and a good aftermarket chip and it will run with the big dogs.
The Following User Says Thank You to rerod8 For This Useful Post:
fordss (10-10-2012)
  #20 (permalink)
Old 10-09-2012, 06:17 PM
Oldsmobile diesels were regularly converted to gasoline. Mondello sold a kit for a while. Of course, Olds gas engine heads and intake were a bolt-on and the diesel block retained the distributor drive provision (there was a vacuum pump in the hole that also drove the oil pump) so it was an easy swap. Change the cam, add a distributor, flush the fuel system, and you're good to go.
A 6.2 is a dedicated diesel. There are no gasoline heads that fit and the diesel combustion chamber is unsuitable for gasoline. Can it be done? Sure, given enough time and money. Is it remotely worth it? Well, the result will be a heavy gasoline engine that was expensive to build, with crappy performance.
Again, if the engine is based on an existing gasoline engine, the conversion is relatively easy and inexpensive. Converting a dedicated diesel is not.
The Following User Says Thank You to joe_padavano For This Useful Post:
fordss (10-10-2012)
  #21 (permalink)
Old 10-11-2012, 01:48 PM
TWX TWX is offline
I know that there are some engines that are used in real Hummers that are multifuel, I don't know what they're based on though. They're specifically designed to be multifuel.
  #22 (permalink)
Old 10-11-2012, 05:31 PM
vinniekq2's Avatar
why dont you convert that diesel to burn kerosene/jet fuel/coal oil and bio diesel?
,,,,,,,lol
I am looking to convert a gasoline car into a diesel. Can that be done? and How?? lifes2short Engine 4 04-18-2012 06:01 PM
diesel engine to gas conversion with T-400 trans RedBush1 Transmission - Rearend 16 04-19-2009 08:17 PM
Diesel or Gas trucks? Gas prices ChevyTruckGuy Hotrodders' Lounge 22 07-12-2007 09:09 PM
converting gas engine to diesel 53LEDSLED Engine 12 02-23-2006 08:01 PM
convert methanol back to gas fbodyfreak Engine 4 01-13-2006 03:06 PM
