can you convert diesel engine to gas ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2012, 10:23 AM
by a head change?
Old 10-05-2012, 11:03 AM
What engine?
Jim
Old 10-05-2012, 11:31 AM
Wiki Edits: 31
vague question. Olds 350 N diesel's I think it's possible but there are not many diesels made from gas engine blocks
Old 10-05-2012, 11:32 AM
vinniekq2's Avatar
why would you consider doing it? even if something as simple as compression change worked,what about the different cam timing and different fuel metering. Diesel engines are designed to work at 3000 rpms or lower,generally speaking
The Following User Says Thank You to vinniekq2 For This Useful Post:
fordss (10-08-2012)
Old 10-08-2012, 07:42 AM
sorry. i just got back . like chevy 6.2 thanks
Old 10-08-2012, 12:28 PM
vinniekq2's Avatar
It would be easier to convert the diesel to dual fuel and use propane
fordss (10-08-2012)
Old 10-08-2012, 03:19 PM
i would like do gas if it can be done thanks
Old 10-08-2012, 03:23 PM
T-bucket23's Avatar
Wiki Edits: 26
There are a lot of things that need to be considered. The whole fuel system will need to be changed, wiring harness, etc etc etc.
Chet
The Following User Says Thank You to T-bucket23 For This Useful Post:
fordss (10-08-2012)
Old 10-08-2012, 04:34 PM
i thinking heads and hei .intake
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cam Lobes
x2
The most sensible thing to do would be a complete engine swap
... or better yet ...
jack up the radiator cap and drive a different truck under it.
Seriously, unless you're emotionally attached to this particular truck ... it's time to trade it in.
Old 10-08-2012, 04:38 PM
66GMC's Avatar
Nope.
There just isn't anywhere to mount an HEI distributor that I know of.
Old 10-08-2012, 04:42 PM
i want to know if can be done or is just not possible to do ? with 6.2 thanks
Old 10-08-2012, 04:53 PM
vinniekq2's Avatar
If you want a straight answer,then yes it can be done.You are dealing with an engine that burns diesel fuel.Gasoline is just another fuel.
fordss (10-08-2012)
Old 10-08-2012, 04:59 PM
ok what engine head would fit ? thanks for your help
Old 10-08-2012, 05:29 PM
66GMC's Avatar
True, Vinnie ... but you need a means of ignition when you are talking about using gasoline or propane as a motor fuel.
Diesel ignites because of the relatively very high compression, and does not require a spark to initiate combustion.
As I said to the OP earlier ... whare are you going to put this suggested HEI distributor? Does the cam have a drive gear on it? Is there a mounting hole for a distributor on a 6.2?
I suppose that you could employ a DIS-like system that uses a crankshaft or camshaft position sensor ... but that's a whole 'nuther level of complication when it comes to a 6.2 GM diesel.
The bottom line is that almost anything CAN be done. The question is (as I see it): "Does it make any sense to do it?"
YMMV
The Following User Says Thank You to 66GMC For This Useful Post:
fordss (10-08-2012)
I am looking to convert a gasoline car into a diesel. Can that be done? and How?? lifes2short Engine 4 04-18-2012 06:01 PM
diesel engine to gas conversion with T-400 trans RedBush1 Transmission - Rearend 16 04-19-2009 08:17 PM
Diesel or Gas trucks? Gas prices ChevyTruckGuy Hotrodders' Lounge 22 07-12-2007 09:09 PM
converting gas engine to diesel 53LEDSLED Engine 12 02-23-2006 08:01 PM
convert methanol back to gas fbodyfreak Engine 4 01-13-2006 03:06 PM
