Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can you fix these seat belts?
Old 08-08-2011, 12:16 AM
matt167 matt167 is online now
Wiki Edits: 31
That webbing is shot and the buckle slider is corroded, causing the problem. Cut them off, clean them up and take care of the corrosion, then take the seat belts to an Auto upholstery shop and have them replace the webbing
