Can you guess this piston dish?? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-19-2012, 08:15 AM
I knew this would come in handy. I started a word document with all my specs. It's a work in progress so bear with me.
GM Block Casting Number
3970010
1969-1979 || 350 ci. || 185 low power || 370 high power || 2 or 4 Bolt Main || car, truck, Vette
Suffix Code on Block Behind Alternator
TKB ||1976 || 350 || conv.cab || VIN: L LS9 || HP: 165 || 4 BBLS || Applications: C-10 & 1500
TKB ||1979 || 350 || conv. cab, m/t || VIN: L LS9 || HP: 165 || 4 BBLS || Applications: C-30 & 3500
Heads Casting Number
14014416
58cc chambers, 1.84/1.50 valves @ stock
Has had 1.97 intake valves put it in
650 CFM Holley
Edelbrock Torquer 2 Intake
4:56 rear end posi (Had stock gears in it before I did a rear end swap)
Cam Specs
I do not know anything about the torque converter.
  #17 (permalink)
Old 06-19-2012, 12:53 PM
F-BIRD'88's Avatar
Yada Yada Yada
The torker II manifold is a dog for this application.
  #18 (permalink)
Old 06-19-2012, 02:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
3970010
14014416
650 CFM Holley
Cam Specs
That cam should give excellent low end torque in a 350 SBC, and given the 4.56 gears, it ought to shred the tires at will- so something is definately wrong here!
What is the initial timing set at? You can do a little research on timing, here is a page that may help you get up to speed (ha) w/the effects of timing on the overall performance of the engine.
Bottom line is I'm thinking you may not have enough initial timing. This may be because the dynamic compression ratio has you up against a detonation problem; a quick fix for that is to use less initial timing- but that can have a very bad effect on performance.
You need to see where you are now; if it's low I would suggest you try around 16 degrees BTDC, but this may require you to limit the mechanical advance so the total timing (initial plus mechanical) doesn't exceed 36 degrees or so.
I'd also suggest along w/a compression and/or leakdown test that you put a vacuum gauge on the engine and see what the vacuum is at idle. Check for vacuum leaks if there's any chance you may have one. The engine should idle pretty smooth w/that cam, so if it's loping/missing at idle, there's a problem that may be ignition (or possible carb) related.
If you do not want to register, fill this field only and the name will be used as user name for your post.
dish or flat top piston? sam_bo3 Engine 3 08-13-2009 10:03 PM
327 with dish piston ellis Engine 1 01-17-2009 01:05 PM
stock CR and piston dish for SBC 350? brian12c Engine 1 02-15-2007 05:31 PM
calculating piston dish cc? firechicken383 Engine 2 06-13-2005 09:16 PM
Difference Between dish and flat piston Parisienne70 Engine 3 02-15-2005 10:10 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
