Looks to be a Chevy 3-speed...either a Saginaw or a Muncie.
I could use some info on this one too.
I just obtained a tranny that looks just like his. It came out of a 72 nova with a 3 sd on the colomn.
If anyone knows what the gear ratios would be I would greatly appreciate a responce Thanks Brad |
Wat it is
It's a 3spd Saginaw - from the tail shaft, from a Camaro, FBird, or light truck - circa 1968-1972??? Lose it - they suck. They were behind 6cyls for the most part, very light duty, and they like to blow syncs if you try to marry up more than 200Hp to them - not to mention other types of more unseemly detonations. Still - if someone is a resto freak, theywill be looking for one of these. Anyone's guess as to ratios, but it is not geared low - and the value - if you can figure out ebay values, you are way ahead of me! My guess at a junkyard you'd be in the 50-75 range. When you list it - count the output and input shaft splines - they changed over the years, so list them and you will save yourself headaches when a buyer complains it does not fit!
YUP ...Saginaw 3 spd! They not a bad tranny!!! They got a synchro 1st gear! and pretty strong! ...Cast is cast iron ...ie HEAVY. AND it's rough finding GOOD after the market shifter. Good Luck! ...Mark
