no pic but you are probly talking about the carbon canister inthe drivers corner front engine bayyou can remove it if you wish but there is a gas tank vent line attaching to it that cannot be plugged or your car wont run for very long before it tries to suck the gas tank closed
Forsaken: You are correct...it's a vacuum reserve tank. It stores vacuum for times when vacuum is needed but not being produced by the engine, or gives you a reserve in case the engine dies. Hot-rodders with big cams use those for storing vacuum for the power brakes, and there are smaller ones used for the vacuum-operated heater/AC controls. It's not necessary, for the most part, but I'd set it on a shelf in your shop...just in case you decide you might want to use it later.
Keith |
Nothing worse than driving up a hill or passing someone and the panel vents blowing nice cold A/C on you are now blowing out the defrost.
Take the line going in and connect it with the one going out. You'll just have to try it to see if you can live with it. It doesn't have anything to do with the power brakes. Years ago people would lose thier windshield wipers while climbing a hill because they were vacuum operated.
well, my heater controls aren't vaccuum operated and I don't have AC (removed it, to expensive to fix), it has a power brake booster, but I'll see if I can live without it
