Can you install a radiator on its side? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2010, 02:27 PM
Ok I am building a "rat rod" 46 chevy truck body on a 85 s10 with a somewhat built 350, I am going fenderless and puting a 36 front grille on, my question is can I mount the radiator on its side? It would than fit in the 36 grille, the top radiator hose would be where the bottom hose was and vise versa, the cap would still be on top, seems like it would work but what do I do with the trans lines they will both be on top? or is there other issus I am not considering?
Old 07-10-2010, 03:44 PM
poncho62's Avatar
Wiki Edits: 5
Guess you could.....I would think you would have trouble getting the coolant in......and your trans cooler would be in the hot water, if it was in water at all.....and wouldn't be cooling anything.........Look for a upright rad.
Old 07-10-2010, 03:56 PM
Irelands child's Avatar
As long as the engine intake is low and the return is high, you should be able to turn it on its side. As far as cooling the tranny - just use an after market cooler. Seems to me that some '60's Fords had this with a separate return tank to fill the system. Look at the first picture here: http://www.midlifeclassics.com/63Galaxie2drSedan.html
The actual rad is like this: http://classicfordradiator.com/60-63...wradiator.aspx
And yes, I did own a '63
Dave W
Irelands child
Old 07-10-2010, 04:32 PM
ok so I was thinking of using the drain petcock for the cold to trans cooler(which will still be on the bottom of the sideways rad) and use the one of the holes on top(as now both the original trans line are on top) as the hot, if I am thinking right and as Irelands child said intake(cold) is low return(hot) is high, thats the same with the trans cooler right, so other than being harder to fill IT SHOULD WORK????? RIGHT??????? or do I think to much (and I could rig a tank to fill like the Galaixes had (I had a 64)
Old 07-10-2010, 04:51 PM
BOBCRMAN@aol.com's Avatar
The radiator in my 36 Terraplane is a GM unit turned on its side with a Ford type puke tank on the top outer side..
Trans cooler is now at the bottom.. Has worked for years.. SBC/turbo trans powered..
Old 07-10-2010, 05:54 PM
poncho62's Avatar
Wiki Edits: 5
You better have a look at how the trans cooler works..........hooking it to that petcock will NOT work......
Old 07-10-2010, 06:17 PM
To be honest I dont know how a trans cooler works (or alot of things learning as I go as this is my first build), there is a line at the top and bottom of my radiator that goes to the trans(some kind of inside cooler right), if I flip the rad on its side both of those holes on the rad will be on top, but the petcock will still be on the bottom and they look to be the same size hole(I think) will it not circulate to the trans or???
Old 07-10-2010, 06:36 PM
the pet **** drains coolant..... the tranny lines cary tranny fluid. unless you have a tranny and engine that likes coolant oil blend.
Old 07-10-2010, 06:37 PM
poncho62's Avatar
Wiki Edits: 5
Thing is.....the trans fluid comes from the transmission, into one of those fittings. There is a tube that takes it through the coolant and back to the trans from the other fitting.......If you hook your trans line to the petcock, you will be mixing the trans fluid with the coolant..........
Old 07-10-2010, 07:32 PM
Thanks everyone......ok, told you I was learning, but I could flip radiator on side and get a seperate trans oil cooler for like $50 from auto store. and I would mount in front of radiator right(so it would go trans cooler, rad, fan. or can I mount away from fan like on the very bottom or the very top? Or do I need to get this side ways radiator thing out of my head and drop $350 on a new radiator? THANKS AGAIN
Old 07-10-2010, 07:38 PM
life is a temporary assignment
The oil cooler in a rad is only a tubing rolled in a coil..Goes in one in out the other..You don't want to hook it to the pet drain..You will not like the results.
Idiot Proofing My Trailer Wires Rob Keller Electrical 41 05-14-2007 08:32 AM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 12:36 PM
34 pontiac 81 camaro subframe install ? mobythevan Suspension - Brakes - Steering 7 05-19-2005 01:17 PM
ring and pinion install red_rider52 Transmission - Rearend 10 04-10-2005 10:34 PM
one side is1.75" lower than the other side. brian400ex Suspension - Brakes - Steering 15 04-01-2004 05:34 PM
