Can you Interchange Fwd 3.1 Engine to Rwd 3.1 Car? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2010, 11:05 PM
I have a 1992 Camaro with a 3.1 V6 thats bad, was fitna do the Ls1 swap but money got tight, finding another rwd 3.1 engine at a halfway decent price has proven harder than expected. My question is, will the 3100 series fwd motors out of corsica's, beretta's, lumina's etc... bolt up to my Rwd Transmission? Is Bellhousing bolt pattern same? Any help would be great, thanks.
Old 09-10-2010, 01:06 AM
DoubleVision's Avatar
I don`t think so, but not sure, if memory serves, one is a 60 degree V6, the other is a 90 degree.
Old 09-10-2010, 04:56 AM
tnsmith10's Avatar
when will it rain???
no, they are not interchangeable. the blocks are different castings. they both are 60 degree bell housing bolt up, but you will wind up with too much spacing between the torque converter and the flexplate to bolt up the converter.
Old 09-10-2010, 05:45 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
It will bolt up to the bell. The dissapointment comes before that when you discover there is nothing to bolt motor mounts to as the front wheel drive blocks are different from the rwd blocks in that respect. fwd and rwd engine mount bosses are different and in different locations. Take a good look.
The 3.1 in your camaro is a 60 degree v 6 and so is the 3100 and the 3400 and the new generation 3500.
Paint and body work warranties ? juggernaut Body - Exterior 12 01-29-2010 06:14 PM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
donk or lambo's got nothing on this 406chevycaprice Hotrodders' Lounge 28 01-28-2008 08:09 AM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
start my engine outside my car? nitsud08 Hotrodding Basics 13 06-14-2005 11:55 PM
