can you paint exhaust manifolds? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2002, 12:43 PM
Post can you paint exhaust manifolds?
hey guys me again i have another ? i have tried with no luck in the past to paint exhaust manifolds i used high heat paint but it came right back off so does anyone know if they make a paint that will hold up to all the heat of rxhaust manifolds. thanks for the help
Old 09-02-2002, 01:35 PM
4 Jaw Chuck's Avatar
Post
Aluminum plasma spray is the only thing I have found that works for any length of time. Zircionia plasma spray works good too, the beauty is you can wash with CLR after to bring back the shine.
— Han Solo
Old 09-02-2002, 02:28 PM
Post
thanks 4jaw... i just built this motor and it looks great dont wanna ruin the looks with ugly manifolds so thanks again and ill try that
Old 09-02-2002, 02:32 PM
Post
oh by the way where can you find that stuff cause i have never heard of it
Old 09-02-2002, 04:57 PM
hotrodit's Avatar
Talking
Vitreous enamel the same as Jaguar used on their manifolds years ago, check out an XKE! has to be done by a specialist though & i know you can still get done here in the UK. Maybe try a search on the net, just another option.
Old 09-02-2002, 07:41 PM
Post
Plasma spray can best be described by this link.
Most large machine shops with extensive welding facilities do plasma spraying, The aluminum spray looks nice and is easily cleaned with CLR or other acid based cleaner. Make sure they put on a nice heavy coat and have them preheat your castings for optimum adhesion. It is basically a sacrificial coating and will corrode first before the parent metal. Cast iron manifolds look great afterward and I use this for headers too.
— Han Solo
Old 09-02-2002, 07:45 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I wouldn't consider building an engine without having my headers coated with the Jet Hot (other companies out there do it too, check ads in rod magazines) metallic-ceramic coating. It is as near a permanent fix as you will find. My Willys headers are 7 years old with fairly steady service and look as good as the day they came back. For all the pipes back from the headers, powder coating, any color you want, works great. Won't burn or flake off.
Old 09-03-2002, 09:18 AM
Post
I agree Jet Hot is the best but expensive to have a cast iron manifold done. The best part is like Willy says it does not discolor at all.
— Han Solo
Old 09-03-2002, 12:42 PM
Madd Syntst's Avatar
Returning American Maddman
Post
This si not as high dollar, but I have had good results with an Eastwood Stainless High Heat coating mix. I put the manifolds in the oven (that pst her off) and got them hot. Then used an acid brush to paint the stuff on. It holds up very well. I would like to Powder coat my manifolds as well, but no bucks for that!
Old 09-03-2002, 04:02 PM
Post
well thanks alot guys for all the help i have some ideas to go on now ill check around and find out who does this stuff and go from there thanks again guys
Old 09-03-2002, 06:46 PM
New Member
Post
i have had good luck , with any of several brands of "hi-heat " paints , even bar-b-q paint ..the trick is preperation , and some heat .. first thing is sandblast the manifolds to get all the crud and old coatings off .. hang in ventilated area , wash down with laquer thinners to get the oils off , then warm them to "can't touch " hot with propane torch ,or acet torch ."assuming you can't put them in the oven ".. the heat both drives any moisture out , and helps the paint "flash-off " ,between coats ..talking spray bombs here ..several lite coats , let tack off 3 to 5 min per coat .. once you'v got good coverage , gently re-heat , thru the ports , and outlet , then leave them alone for a couple of days .. if its warm/hot where you are , hang them outside in the sun .. mother natures bake oven ... works for me , good luck ..jim prowse..
Old 09-04-2002, 05:47 AM
Post
thanks i might try that too just not sure which way im goin yet but at least i have lots of idea thanks
Old 09-04-2002, 02:51 PM
HotRodS10's Avatar
All Throttle...No Bottle
Post
How well does Powder Coating work on headers? I actually had this conversation with a buddy of mine last week and he said it would work good....has any of you guys tried this yet? If so how is it holding up?
Old 09-04-2002, 04:15 PM
Post
well i called a guy today to see about powder coating my manifolds and he said that it would never last i told him that i had heard of people doing it to theirs and they had good luck and he said no way it will not work and he owned a powder coating place so not sure if he knows what he is talking about or not so im gonna try one of the ideas you guys have given me here just not sure which one yet
Old 09-04-2002, 09:09 PM
Post
Powder coating is polyester based, how long would a pair of polyester pants last on your exhaust manifold? The plaid ones last 10 seconds longer than striped.
Powder coat will not work on exhaust manifolds/headers, heads, intakes (with exhaust crossovers) or polyester pants. :p
— Han Solo
