Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - can you put any 8.5 10 bolt gear in a 8.5 rear end?
Old 07-31-2012, 07:01 AM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
Yes, even the later 8.6 gears will work. Also the 8.5 front axle in the late '70s and early '80s 4X4 trucks use the same gears.
The Impala Caprice rear ends used a reluctor ring on the pinion shaft. The pinion shaft in these rear ends were different from others. It's not a problem if you are using an Impala Caprice gear in another rear end, but if you are using other gears in an Impala Caprice rear end you will not be able to use the ring and the speedometer and anti lock brakes will not work.
