Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - can you put any 8.5 10 bolt gear in a 8.5 rear end?
Old 07-31-2012, 07:34 AM
lmsport lmsport is offline
There are two ring gear carriers series for the 8.5 axle. One for one 2.56 and numerically lower gear ratios, and one for 2.73 and numerically higher, so you have to keep that in mind if swapping gears between different housings and carriers.
