can you put any 8.5 10 bolt gear in a 8.5 rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2012, 08:12 PM
can you put any 8.5 10 bolt gear in a rear end? Like a truck gear as long as its 10 bolt 8.5 .
Old 07-30-2012, 08:19 PM
prostreet6t9's Avatar
Differential/Driveline
Yes you can.
Old 07-30-2012, 08:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
killer-k, I edited the thread title.
Since you have two threads with the same title it confuses the membership
Old 07-31-2012, 06:01 AM
big gear head's Avatar
High Performance Rear Ends
Yes, even the later 8.6 gears will work. Also the 8.5 front axle in the late '70s and early '80s 4X4 trucks use the same gears.
The Impala Caprice rear ends used a reluctor ring on the pinion shaft. The pinion shaft in these rear ends were different from others. It's not a problem if you are using an Impala Caprice gear in another rear end, but if you are using other gears in an Impala Caprice rear end you will not be able to use the ring and the speedometer and anti lock brakes will not work.
Old 07-31-2012, 07:34 AM
There are two ring gear carriers series for the 8.5 axle. One for one 2.56 and numerically lower gear ratios, and one for 2.73 and numerically higher, so you have to keep that in mind if swapping gears between different housings and carriers.
Gear swap in 10 bolt rear end 1987 Cutlass pena0724 Transmission - Rearend 2 07-16-2009 10:27 PM
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 05:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
rear end out put yoke??? tinman386 Transmission - Rearend 7 09-25-2007 06:37 AM
can i put 8.5 into 7.5 rear end houseing bradsregal85 Transmission - Rearend 2 02-25-2003 06:11 PM
