Can you put filler over self-etching Primer? Safely - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-19-2013, 12:34 PM
If I sandblast my frame can I spray it with self etching primer, then Lead-filler and then shop primer?
Or is that completly no go?
  #17 (permalink)
Old 04-19-2013, 02:16 PM
"Can you?" I have seen it done without failure but it makes no sense and honestly, get yourself epoxy primer for that frame. Once sand blasted that is your best choice.
I remember on a SW etch prime tech sheet it said it could be applied OVER polyester filler ("bondo") as long as the filler was "fully cured" which was 12 hours. So if applying etch over fully cured is required how can you apply wet filler over the etch? It's a disaster waiting to happen in my opinion.
epoxy or etching primer over bare metal? pineknot Body - Exterior 21 03-16-2007 07:53 PM
Non etching primer or epoxy Skipr Body - Exterior 9 12-01-2005 10:21 PM
Fiberglass Hood, Etching Primer? Custom95Z Body - Exterior 21 08-25-2004 12:48 PM
Do you need etching primer under featherfill primer? Fordy8man Body - Exterior 14 10-29-2003 07:23 PM
etching primer readyeddie Body - Exterior 9 10-20-2003 10:02 PM
