Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can you reverse a R and P
Old 04-19-2013, 10:05 AM
joe_padavano joe_padavano is offline
Unisteer sells a bolt-in R&P kit for the S-10 chassis, though this does beg the question if you went through all the trouble to swap a frame to get modern suspension, steering, and brakes, why did you then muck with the steering? Might be a whole lot easier (and DEFINITELY cheaper) to get a quick ratio box for the stock S-10 steering linkage.
