Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can you reverse a R and P
Old 04-19-2013, 04:25 PM
sbutler sbutler is offline
Joe, thanks for input. I'll try to address your questions. The Unisteer only comes in a manual steer set up. Guess I'm spoiled. Instead of setting my 39 body on top of the deep S-10 frame, I channelled it 5", which opened up problems of it's own. The factory steering box was running directly into the power steering pump. I cut the frame horn and moved the box over 2 1/4" and tilted it up just a few degrees. After lengthening the center link, done by a certified welder and where it would not effect the steering, I discovered that screwing with this really bit me in the ***. So back to the center take off rack, which would work great if it was for front steer. If anyone can help identify a center take off, front steer rack, I can make this work. Thanks again, Steve
