Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can you reverse a R and P
Old 04-22-2013, 10:10 PM
sbutler sbutler is offline
Joe. I cut the tie rod mounting section from the center link and re-installed it on the tie rods. This will let me keep the tie rod orientation the same as stock. When I get the rack located with new brackets I'll make a simple bracket that will bolt to the rack as the stock tie rods did and it will extend back to the stock tie rod section and be welded there, hopefully giving me better than stock steering. If you see problems with this please interject. Would really like to get this part wrapped up so I can proceed with the build. Thanks, Steve
