Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can you reverse a R and P
Old 04-30-2013, 02:05 AM
jayd_2 jayd_2 is offline
I put a '37 dodge pickup on an S10 frame, had to shorten the frame horns so much that I could not use a GM power or manual box. I used a rack from 1994 Dodge Intrepid, its a center mount style rack so the tie rods are plenty long so there's no problem with bump steer. I used 16mm & 18mm o-ring to AN6 adapters from Speedway to plumb it up, used a GM pump. It's mounted in front of the cross member and has hiems in the center with stock S10 tie rod ends. I also used a flow reducer that drops the pump flow from 3GPM to 2GPM. Had to use block hugger headers to get the steering shaft clearance. Can post some pics if you need to see the setup.
The Following User Says Thank You to jayd_2 For This Useful Post:
sbutler (04-30-2013)
