-   -   Can you take guide coat off with acetone? (http://www.hotrodders.com/forum/can-you-take-guide-coat-off-acetone-174907.html)
Mycophiles 03-21-2010 02:40 PM
I used a spray - type guide coat and the nooks and crannies of the car are difficult to get to. I was wondering if I could use acetone to take the guide coat off. The can says to take overspray off with acetone but I'm not sure if it means overspray on the paint or overspray on non-painted areas.
302 Z28 03-21-2010 03:26 PM
You must have put your guide coat on too heavy, all you needed was a very light dusting. To answer your question, yes you can remove it with acetone. Do not wet the surface profusely or you will take off the primer also.
Vince
MARTINSR 03-21-2010 06:30 PM
I would think about sanding it all off. I have never found a need to "clean" it out of anything, just sand it out.
Acetone is a VERY heavy, slow evaporating solvent and it can soak into primers and such before you know it. I would avoid it and just sand the stuff out.
mitmaks 03-22-2010 04:52 AM
you should've masked off areas where you didn't want it on.
deadbodyman 03-22-2010 07:16 AM
lacquer thinner evaporates faster and might be better ,I've never done it...Did you guide coat Paint???? or primer? If primer what kind?
