Can you take guide coat off with acetone? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2010, 02:40 PM
I used a spray - type guide coat and the nooks and crannies of the car are difficult to get to. I was wondering if I could use acetone to take the guide coat off. The can says to take overspray off with acetone but I'm not sure if it means overspray on the paint or overspray on non-painted areas.
Old 03-21-2010, 03:26 PM
302 Z28's Avatar
You must have put your guide coat on too heavy, all you needed was a very light dusting. To answer your question, yes you can remove it with acetone. Do not wet the surface profusely or you will take off the primer also.
Vince
Old 03-21-2010, 06:30 PM
I would think about sanding it all off. I have never found a need to "clean" it out of anything, just sand it out.
Acetone is a VERY heavy, slow evaporating solvent and it can soak into primers and such before you know it. I would avoid it and just sand the stuff out.
Old 03-22-2010, 04:52 AM
mitmaks's Avatar
Last journal entry: Grille
you should've masked off areas where you didn't want it on.
Old 03-22-2010, 07:16 AM
deadbodyman's Avatar
Wiki Edits: 11
lacquer thinner evaporates faster and might be better ,I've never done it...Did you guide coat Paint???? or primer? If primer what kind?
Eliminate filler pinholes with dental pik and credit card cboy Body - Exterior 8 05-21-2009 05:48 AM
Dry Guide Coat? Arrowhead Body - Exterior 17 03-05-2009 04:36 PM
I'm having problems with guide coat Ripped Body - Exterior 7 03-01-2007 04:08 PM
Filler Over Guide Coat? 68NovaSS Body - Exterior 5 06-17-2006 09:03 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
