canadian 2 barrel intake any one answer question on it - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2013, 10:26 PM
So I bought a 59 chevy pu with what I'm assuming to be a 307 or 327 has a Canadian intake I was reading that it has no egr stuff and less likely to have vacuum leaks is there more to it ***
Last edited by 68NovaSS; 03-29-2013 at 03:09 PM. Reason: Can't sell or hint at it here and email addresses not allowed in posts.
Old 03-29-2013, 05:54 AM
bondo's Avatar
*****,.... What makes ya think it's Canadian, 'n not just a pre-smog control piece,..??
Old 03-29-2013, 09:16 AM
poncho62's Avatar
Wiki Edits: 5
EGR valves were not used until the early 70s....74, I think
327 came out in 62 and 307 in 68......Best check your engine numbers. If stock, its a 283
Old 03-29-2013, 09:25 AM
BOBCRMAN@aol.com's Avatar
Value depends on the part no. The best ones are from dump trucks and school bus. 313, 467, 752
Only people that want these are left hand turn Hobby stock cars limited to a factory cast iron two bbl intake..
Old 03-29-2013, 11:11 AM
I will check but motor is not original .... the guy I bought truck from said its a 327 but front numbers on block don't lead to anything so I have been trying to get the back ones but motor to tight to fire wall I will pull numbers of the intake ...... please answer this ...... why would they put a 2bbl on a dump truck or school bus
Old 03-29-2013, 12:03 PM
I got a 327 out of a school bus .. 64 i believe ..
It had a two barrel .. 75 cc heads and dish pistons ..
Old 03-29-2013, 01:20 PM
RWENUTS's Avatar
Easiest way to see the casting number is a mirror and a flashlight. Angle the mirror towards the back of the head and point the flashlight at the mirror.
Easy to read that way.
Old 03-29-2013, 04:58 PM
...... why would they put a 2bbl on a dump truck or school bus "
Simple it's called Fuel economy! That and a natural speed governor. Those engines were designed to make low end power, no need to rev them up past 2800 rpm, thus no need for four bbl carb.
I worked on and drove some of those old busses. Sound like they are going to explode at 3200 rpm..
Old 03-29-2013, 06:49 PM
there was no such thing as a big motor in the late 50's and early sixty's
Most of the trucks had a six or a 283.. and were geared low ..
no need for a big motor ..
used the same amount of gas empty or loaded or very little difference anyway.
When you were in high gear , yuo were looking for one more gear ..
even alot of 69 -70 one tons came with the six and a bow low four speed .
Kept the motor out of a 59 three ton and it was a 283
Old 07-26-2015, 03:27 PM
Flipper_1938's Avatar
I've never seen a SBC that wouldn't rev any more than that. What did they differently on the truck motors? Was it all just the carb being too restrictive?
2 barrel adapter to 1 barrel intake? 1969f-100 Engine 4 10-30-2008 08:06 AM
sbc 6 - 2 barrel intake on ebay crshrmn3 Hotrodders' Lounge 0 09-09-2003 10:20 AM
4-Barrel Stock Intake Maniford Jim69Mustang Engine 3 08-30-2003 09:00 AM
stock 4 barrel intake oldscutlass General Rodding Tech 2 08-21-2003 06:47 PM
Should I run a 2 barrel intake? CrazyT Engine 2 12-07-2002 11:05 PM
