CANCER ON THE BODY - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2003, 07:04 PM
Post CANCER ON THE BODY
WHATS THE BEST WAY TO FIX CANCER ON A CAR BODY YOUR GOING TO KEEP FOR A LONG TIME
Old 02-14-2003, 07:13 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Depends on how bad it is. If its just surfact rust all you need to do is remove it and use a etching primer/sealer or use a product like POR-15. If the rust has created holes you will need to cut out the rusted area and replace it thrugh welding in patch panel then to prevent it from happening again use a etching primer/sealer or a product like POR-15.
HK
