Candy.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2003, 08:10 PM
DigitalW's Avatar
PAINter
Unhappy Candy....
This week I have a '98 Yukon that I have to completely change the color on. They are converting it to a cadillac/Denali. It's Black, and they want it painted Metallic red candy.
I've used House of color candy before, and did'nt have much problem with it, but my jobber decided I should use PPG candy, and frankly.....it stinks...:/
My problem is, this is the first all over candy I've done with this DMX213 dye stuff.
I sprayed a test hood, and I just can't seem to get the mottle to dissapear, and the stuff is really thin(watery/too transparent). Any suggestions????
btw, I'm using Global paint system, and have been a painter for 10 years. Thanx in advance...
Old 06-23-2003, 08:34 PM
DigitalW's Avatar
PAINter
Just thought of something...
I did read the other Kandy paint threads in this forum before posting, but basically I was just wondering if anyone else has used this combination before, and did it give them any problems.
Old 06-27-2003, 08:15 PM
MadRabbit's Avatar
ya just need a bigger hammer
This site might have the info you are looking for if you haven't figured it out yet
http://cararts.com/homepage.html
they had answers for me ...I've done bodywork for 10 yrs off and on but never painted now I plan to paint my 69 impala as soon as I get the body straight..let me know what you find out you never know you might tell me the tidbit that could change my paint job from orange peely to glass smooth
Old 06-29-2003, 02:30 PM
DigitalW's Avatar
PAINter
Thanx for the info...
About making your paint smooth, and not as peely. Dont spray your basecoat on too dry it can cause the peely look in your clear. Also when your clearing dont pile the clear on it only makes the orange peel larger and it may solvent pop. Best thing to do is take your time, and back up to about 6-8 inches from the car with your gun and go a little slower.
If your using single stage paint, spray it the same way you spray your clear. There are other factors in making your paint smoother, like types of reducer you use, type of clear, hardner etc... If your painting it in a garage or at home somewhere, you can't help but use fast reducer, and clears. But if you have a booth to spray in, the slower the stuff dries, the slicker it will be. again take your time, and dont but your coats on back to back.....good way to get runs...
