cani convert to msd disrtibuter - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-25-2012, 02:15 PM
I want to convert to a msd distributer , with the pro flo 3500 series, do i need use the amplifier from edelbrock or can i use a 6al box, and how do i wire it into the system, please help thanks
Old 02-26-2012, 12:15 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
You can use a 6al. The ecu triggers that little amp just like it would a 6al. If I remember correctly you can hook it up to the distributor input on the 6al. All that little box is, is a distributor module with a little box made around it so it is looking for the same signal as an HEI distributor is. It is a mickey mouse setup for sure, but you can fix that with the 6al.
Recent Modern Electronic Engines posts with photos
trying to convert in lb into ft lb. mitmaks General Rodding Tech 8 10-06-2009 05:45 AM
cani put a 350CID,out of 95-00 zz4, in 94 caprice Seanj Engine 5 08-25-2009 07:41 PM
plz help s15 blew up. 98 blazer tranny blew cani swap engines disice1011 Engine 2 12-02-2008 09:33 PM
how to convert over to a 4x4....maybe? jesse01 General Rodding Tech 8 08-17-2007 10:41 PM
convert from 4 lug to 5 lug cesar9 Body - Exterior 7 11-25-2004 10:56 PM
