Canister to spin on oil filter adapter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2006, 10:41 AM
I know this question has been asked here, but I didn't see the answer I was looking for. I have a 62' 327 motor that I want to use a regular spin on type oil filter. It is setup for the old Canister style. I got an adapter from summit, but it needs the by-pass valve, which I don't have. Should I just re-order the kit that includes this, or should I go to the junkyard and root around for this? I also see advice to use a good quality one. Can someone suggest a good quality kit for this? Thanks!
Old 04-27-2006, 03:01 PM
2000jack's Avatar
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
I have had very good luck in returning items to Summit. If they have it, sounds a lot easier to send it back than hit the junk yard.
Old 04-27-2006, 03:14 PM
302 Z28's Avatar
It is true, returning an item to Summit is great, if that part was not in the kit. If that part was not part of the kit you will have to pay shipping back to Summit. You will have to pay shipping regardless, you just will not be reimbursed for it. It may be cheaper to go to junk yard or to a GM dealer.
Vince
Old 04-27-2006, 07:12 PM
Wiki Edits: 31
could always run a filter with a bypass in it if you don't want to return it.
Best oil filter bfr57 Engine 131 10-12-2009 04:10 PM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 02:51 PM
Oil Filter Adapter DTL504 Engine 1 03-23-2004 08:23 PM
v6 remote oil filter? sosky Engine 3 03-31-2002 04:05 AM
oil filter adapter Charlieman2 Engine 3 01-30-2002 02:10 PM
