can't figure it out! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2009, 04:03 PM
I have a 1973 pontiac ventura that is about 70% finished. One of the main things giving me problems is wiring my charging system. When I got the car it was mostly in parts. The engine is brand new, as well as the rear end, tranny, interior, and all the glass. The problem with the wiring is that the car came with points and a external voltage regulator, but has been switched over to HEI with an internally regulated alternator. I have obtained wiring diagrams for the original way it was wired and a diagram on how to wire it with HEI and the alternator it has now. The problem is how to combine the two. I have it running and I think it is running on the battery not the alternator. I am confused by the wiring going to the horn relay, fusible links( or lack of ), and which wires go from the alt. to the starter, etc. Any help would greatly appreciated. Thanks
Old 09-03-2009, 04:23 PM
fast68's Avatar
likes chevy trucks & boobies
hei simply connects to switched full 12v source
plug it into the ign port on the fuse panel
the charging system will be simple
just connect all the bigger red wires to the charging post on the alt and loop a short length one from the spade conector on the side f the alt to the charging post
the small wire on the other spade on the side of the alt goes to the dash light or guage(white wire on external regulator wiring harness plug
blue wire do away with- no longer needed
red wire to alt charging post or to battery
done
simple
all the red wires need to be full hot at all times
surprised a 73 would not habd internally regulated alt on it
73-up were all internally regulated that ive ever seen
even the trucks, and was the first year for this system.,
so thats odd,,
Old 09-04-2009, 09:31 AM
Thanks for the help! as soon as I get out to the garage I will try your suggestions. I,m surprised you haven,t heard of a 73 gm with an external voltage regulator, everywhere I go they say it,s pretty common. At any rate you have been helpful and i sure appreciate it.
Old 09-04-2009, 10:31 AM
302 Z28's Avatar
Make sure that you hook up the HEI to a dedicated 12 volt supply. Do not run anything else off that circuit as it could degrade the preformance of the HEI.
Vince
Old 09-04-2009, 11:43 PM
Thanks for the help guys, I finally got it working. It ended up being not having the field wire hooked up properly.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Cant figure out this tranny? fordsucks7 Transmission - Rearend 5 03-23-2009 11:10 PM
Can't figure out this oil leak!!!! sexypizzaman Engine 16 07-16-2008 08:38 PM
How to figure compression ratio...... classic_chevy_guy Engine 9 07-26-2005 09:59 PM
Figure this one out willowbilly3 Electrical 7 12-25-2004 04:56 PM
