Can't figure out Ford 8.8 Bushing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2012, 01:27 PM
Elevinpointsixtoone's Avatar
Howdy, hey I'm having a heck of a time trying to locate a set of replacement OE style bushings for my Merc/Ford 8.8 axle. I need the housing bushing that I think is referred to a control arm bushing (adding confusion to my search). The axle is a 91 Merc Grand Marquis. So can you tell me if these housing bushings are
a) called rear control arm bushings
b) are they the same as the easy to find Mustang 8.8 rear control bushings
c) are these bushings the same as the front upper control arm bushings as I see noted in all of the bushings for the Mustangs?
See my pic for a shot of the axle bushings removed but the bushings are sitting in the lower left area of the pic amongst all the other crap.
Thanks,
Dave
Old 05-24-2012, 02:33 PM
Raybestos 5701033
Old 05-24-2012, 02:49 PM
All the listings for this part number say its for the lower control arm....are uppers and lowers the same?
Thanks,
Dave
71/2 degree bushing for a Ford tie rod end needed New Bird Suspension - Brakes - Steering 2 07-09-2011 08:05 AM
bushing driver- trans. pump bushing. Chevy350Sb Garage - Tools 2 10-14-2009 09:45 PM
Can't figure it out? Marcus Transmission - Rearend 0 06-20-2004 08:25 PM
429 still hates me, go figure i go from chevy to ford. Jared Engine 6 01-13-2004 10:23 PM
Ford Radius Arm Bushing Repair dmorris1200 Suspension - Brakes - Steering 0 05-03-2003 04:09 PM
