Can't figure out what crank I have - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2005, 05:06 PM
Mad Maggot's Avatar
The lean mean donut machine
I have a buddy who tore apart the engine he got with an 85 Monte Carlo he had just bought. He had a bunch of go-fast parts and he wanted to rebuild the 305 that came with the car and hop it up a bit. As he tore it apart he discovered that the engine had a .030 overbore and that the motor looked like it did not have many miles on it since the rebuild as there was still hone scratches and there was no noticable ridge at the top of the bores. So, the motor had obviously been torn apart before to get rebuilt. As he took out the crank and set it on the concrete, he noticed it made a high pitched ding rather than a thud. He took a wrench and tapped the crank, and it rang like a bell. He then compared it to the camshaft which made a thud, so he automatically assumed that someone put a forged crank in it when it was rebuilt. I told him that cast steel cranks can also ring like the forged ones, and that some stock motors came with cast steel cranks as opposed to cast iron. We both agree it is not some cheap cast iron crank, but none of us are certain what it actually is as the casting number is too garbled to read. Is there any way of knowing what crank this actually is? He said that if it is a forged crank he will put it toward his circle track 355 project, and if it is cast he will just use it in his 305, so he really needs to know the difference.
Thanks for the input
- MM
Old 11-06-2005, 05:23 PM
techinspector1's Avatar
Wiki Edits: 326
Look at the first un-machined part of the crank at the front. If it has a very thin parting line, it's cast. If the parting line looks like someone took a grinding disc to it and is about 1/4" wide, it's forged.
Old 11-06-2005, 07:04 PM
BOBCRMAN@aol.com's Avatar
Cast Iron cranks can ring to the untrained/experienced ear. The "thud" ones are usually cracked! As mentioned above, the parting line is the quick and dirty way to tell. Look for the line on the first crank throw
Old 11-06-2005, 09:20 PM
347mustang's Avatar
if it is the orginal crank , no 305 crank is steal, but it is possable that some one put a 350 crank in it cause a 305 and 350 both have a 3.48 stroke
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 10:01 AM
Rebuilt engine won't crank. lt1bbody Engine 10 04-22-2005 12:44 PM
383 Crank Hits Pistons 68NovaSS Engine 17 08-09-2004 02:33 AM
crank problem Zartan Engine 17 05-11-2004 02:39 PM
crank / block combo's toddtheodd Engine 5 03-17-2004 10:38 PM
