Probably not, unless there is a hole in the screen. That doesn't mean that you don't try and keep things real clean.
Ontario Rodders |
poncho62, the reason I was asking is because when I dropped the pan there was a bunch of gasket pieces floating around in the trans. fluid. I'm hoping that those pieces didn't work its' way up into the trans. (I did clean the pan out ). Well hopefully if I have time I will put the pan back on and see if my problem is fixed... thanks a bunch.
I would be more concerned bif there were any metal particles floating around, or attached to the magnet.
BTW, what is the problem with the tranny?
Ontario Rodders |
I wonder if what you think are 'gasket pieces" are really friction material pieces off the clutch packs........? I say this since you have mentioned you know very very little aboutt automatic trannys.
At the Bonneville Salt Flats, first gear is known as 130 mph. Last edited by Crosley; 12-21-2006 at 05:57 PM. Reason: words missing , mis-spelled too |
TH375 |
CROSLEY, you could be right. But looking at the gasket there were chunks missing in the inner parts of the gasket. I didn't have time to put the pan back on and see if the trans. will engage into a gear. Also when my truck was running last year there were no signs of trans slipping. Wouldn't there be a gradual problem with the trans or could it just stop all together?
1... possibly, not always 2... yes
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Well, I put the pan back on and guess what... nothing. I dropped the pan again yesterday and removed the valve body making sure there wasn't any gasket material and such in there, it was clean. Put everything back on and the only change I found is when I run through the gears (with truck off) it's firmer. Anyway , I have one more question. Is there anyway to narrow down the issue with this thing? As I've stated in my last posts when I put the truck in gear I can't feel it engaging. Could this be some internal linkage?
I am not fully understanding your post.... You run it through the gears and it's firmer...... what is firmer? you removed the valve body.... did you hook the internal linkage back into the manual shift valve in the valve body? How much oil are you adding to the tranny when the pan is re-installed? Does it seem to be taking fluid in as the engine idles when you fill the unit? Have you opened up a cooler line fitting to see if oil pressure is there?
Crosley, sorry for being so vague, I'll blame it on inexperience. I haven't checked for the pressure yet. I'll try to start from the beginning. When I was first experiencing problems I would have to rev the motor up quite abit to get the truck to move, seemed like the problem was with reverse only. Then as time went on it would take awhile for the truck to move into drive or low gear , but it would eventually move. Now it's not moving at all. Thinking that I might have not hooked the shifter linkage up correctly I disconnected it and put the trans. into gear by moving the lever on the trans. but still nothing. I'm just not sure what else I can do before taking it in and getting it rebuilt or buying a new transmission. I did hook everything back up correctly to the valve body. Again, sorry for being unclear..
Well, after looking through some posts on transmission problems I'm going to look into my problem again. I'm very stubborn and I will not give up until I know I've done everything I'm capable of (which unfortunately is very little)
I'm wandering if my torque convert is the problem. Is it possible it has moved enough and is not engaged into the trans?? Is there anything specific I should be looking for besides making sure the flex plate is tightened to the crank and the converter is tightened to the fly wheel. How about the gap between the converter and flex plate? |
Any thing specific to check? Yes, verify there is pressure in the cooler lines. This will help determine if the pump is working. There should a good flow of fluid in the cooler line.... not a dribble Is the converter bolted to the flex plate? A simple check, a guess on my part. The converter does not simply back out of the tranny and stop transfer of power Is it possible the converter was jammed against the pump incorrectly during the install and now the pump is blown up ( broke) ? lets us know.
| Where Can I Find Info On Vacume A 350 Chevy | SBC | Engine | 15 | 11-11-2006 05:47 PM |
| Caddy motor cant find cid info help | creativeinteriors | Engine | 3 | 07-17-2004 05:34 PM |
| Eldebrock C33B intake info | Alvin Tench | Engine | 3 | 07-02-2004 12:26 AM |
| Need Help to find Info | countrysidehomes | Hotrodding Basics | 1 | 04-14-2004 10:27 AM |
| Need info on Impala | Burn_em | General Rodding Tech | 3 | 01-28-2004 04:40 PM |
