-   -   Can't find Ford wheel cylinders (http://www.hotrodders.com/forum/cant-find-ford-wheel-cylinders-208658.html)
Blown496 11-13-2011 12:36 PM
I have a large bearing 9" with 11x2 1/4 shoes. The Wagner number on the cylinders is fp 9023. I spend an hour going through boxes at the parts store with my backing plate in hand and their computer doesn't show them. I would thing all big fords are the same but evidently not. My backing plates search on the net only shows up once as 76-77 Bronco but that got us no where.
Centerline 11-13-2011 12:53 PM
First, don't waste your time at the "auto parts store". Napa will have what you need. They may not have it in stock but it usually only takes a day or so for them to get it from the warehouse.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
matt167 11-13-2011 01:12 PM
yep, Napa or Carquest.. The Wagner number could deffinetly be crossed, even if they have to pull out the brake book.
poncho62 11-13-2011 01:14 PM
Book???...They still have those?...... :D
Blown496 11-13-2011 01:30 PM
Napa store had only one match and it is special order for 1 ton 63-66 ford.
66GMC 11-13-2011 01:30 PM
Hmmm .... I wasn't able to cross FP-9023 either.
FD-9023 works ... NAPA NUP 9344 (Raybestos WC-9344), but that number isn't listed to fit any Fords with that size of brakes.
By application:
1976 Bronco with 11 x 2-1/4
NAPA 370192 LH
370193 RH
15/16" bore
These wheel cylinders fit virtually ALL Ford full-size, midsize, E-F150's ... so I think we're on the right track. Just verify that bore size, and perhaps the fitting size/orientation. I'm thinking that it shoud be 7/16-24 thread, but the online catalogs don't give those specs.
I may be able to provide more details from the Illustrated Buyers Guide (paper catalog) when I get back to work on Tuesday.
Thanks for the endorsement, Centerline. :thumbup:
66GMC 11-13-2011 01:34 PM
Yep, that would be using the FD9023 cross-reference. 53-66 F350 which was 1-1/4" bore.
Blown496 11-13-2011 06:53 PM
Thanks for all the help. I took the backing plate to Autozone and asked for 76 Bronco and they fit perfect. Gonna write that on the garage wall in magic marker.
