Hotrodders Bulletin Board
#1
Can't find headers for my 2002 GMC Sierra
I have a 2002 GMC Sierra unfortunately optioned with the 4.3L V6. The truck weighs 4621 lbs on a truck scale, and with 3.08 gears this beast is pretty gutless. I can't complain about the combo because I scored the truck really cheap due to a couple of unsightly dents, and the motor only has 31,800 miles, however I need more power for towing a boat trailor, especially up mountain roads. I've been searching for some headers to help the low and mid RPM range, however I can't find any manufacturer that makes headers for my specific combo. I have found many headers for the 4.3L V6, however they are all specified for S-10's, Blazers and Jimmys, or Sonomas. I really don't want to take the chance of buying a set of these headers only to find out that they do not fit in my truck. I would prefer to find a set of headers designed specifically for my truck with this engine. If anyone knows if the Jimmy/Blazer/S-10 headers will fit in my truck without any special modifications, please let me know. Otherwise, I would appreciate it if someone would point me in the right direction for the headers I am looking for.
PS: I am already going to swap the rear gears for a set of 3.42's. Any higher and I will hurt my gas mileage too much. |
#2
At that weight is this an extended cab...? Also I doubt most anything you do for the little 4.3 V6 will help very much...? Most of these trucks came with either the 4.8 or 5.3 V8`s and they too are somewhat weak on the torque side... (I own one with a 5.3) But of course are better than the V6 version for sure... If you dont have alot in it you may consider switching it to a 5.3 possibly...? Also once these engines get above 2200rpm the torque does come in better... Just my observation when pulling my other 69 C10 to the track...
#3
Nope, if you can believe it, this truck is a regular cab, long box, 2WD setup. If I had a crew cab 4X4, it would weigh over 6,000 lbs. My buddy's Chevy Avalanche weighs 6774 lbs, but of course he has a 502 big block in it. The Dodge and Ford trucks can reach over 7,000 lbs, so it makes the GM trucks look light. I get this information directly from the manufacturers as well as from magazines. I can provide links if it looks unbelievable.
I have already thought about swapping for a V8, but cost is a big concern, not to mention the grief in changing from a V6 to a V8. I'm just looking to hop up my current motor as much as possible while retaining mileage. Headers apparently wake up these little 4.3's pretty good, so that is why I am interested in them. |
#4
Wow... Need to put them on a diet...
Try this part number over at Summit (JBA-1842-1) |
#5
hey, I checked out those headers on JBA's web site... looks like exactly what I was after. Thanks for pointing those bad boys out
My only beef is that they are pretty pricy, and that they are 1-1/2" instead of 1-5/8". Since a 4.3L V6 is pretty much identical to a 350 minus 2 cylinders, I assume that 1-5/8" is the optimal size, considering this is what is recommended on a 350. At this point I'm just glad someone actually makes headers for my combo. Never even heard of JBA until now |
#6
Although not headers it is power, and cheap power at that. The second one even tells you the resistance value ( a smart car guy doesn't need to buy the product after reading the description!). An even smarter car guy could put a variable resistor on the dash that would control the power out-put at the twist of a knob!
http://cgi.ebay.com/ebaymotors/ws/e...item=7977286819 http://cgi.ebay.com/ebaymotors/ws/e...item=7976401080 |
#7
Yes, an ECU upgrade was definitely part of my plan, however I was not expecting to see something so cheap. It makes me a bit skeptical that it really works, seeing as how aftermarket chips run around $400. If this ECU modifier works as well as they say it does, for $25 you can't go wrong. I just hope it's not the kind that requires premium fuel and forbids towing, otherwise I doubt I could use it.
I also plan on upgrading my cam, if that helps. A chip, headers, performance exhaust, head porting (which I will do) and a 210/215 @.050 roller cam should really wake this little engine up. I'm hoping to get over 300 ft-lbs from 2000 to 4000 RPM, where I really need it. |
#8
all it does it trick the cpu into thinking the incoming air is cool, thereby increasing fuel and timing. the piece itself come in packages of 100 for $2-3 at radio shack. It's just knowing which one(size, they are color coded) for which vehicle. They list the size and all. this line says it ALL>
see>>> http://search.ebay.com/20-hp_Car-Tr...atZ6030QQsojsZ1 http://motors.search.ebay.com/_W0QQ...yopopmotorworks http://motors.search.ebay.com/_W0QQsassZdublinQ5fhp <<< |
#9
I may have a use for the White Lightnin module, but I am cautious about modifying my intake sensor. Since I live in Alberta, cold air is a very common element, and my truck frequently sees sub zero temperatures (sometimes in the -40s). Modifying the intake sensor to read cold air will not accomplish much in these conditions. I am also concerned that when the intake air is hot and the sensor reads cool, it could throw off the air/fuel mixture as warm air atomizes the fuel better. If the computer injects fuel based on cold air readings, it may make the mixture rich. I can't verify this for sure, but it is something worth considering.
I would prefer something that I can adjust the timing and fuel curves based on my own settings, relative to the engine combination in case it is altered. |
#10
We've got a 97' rclb with the 4.3 and it pulls it along pretty good and will roast the tires shifting into 2nd gear(open rear), but it only weighs around 3400lbs according to the title. It's also got 3.42 gears BTW.
#11
Headres for 4.3l VORTEC V6
I had the same problem finding a set, but when I get the money together they are coming home to me. Check it out www.myspace.com/Big_Rick_Nichols
I love my 4.3... |
#12
I sure hope he found them being this thread was started 3 years ago in 2005.
Look at the date before you post. |
Back to top |
Similar Threads for: "Can't find headers for my 2002 GMC Sierra"
| Can not find any headers for my J302 heads? | Sodflyer | Engine | 6 | 05-24-2009 02:06 PM |
| just bought a 94 gmc sierra | shane7643701 | Engine | 8 | 03-01-2004 12:23 AM |
| question on how to remove factory stereo from 94 gmc sierra | shane7643701 | Interior | 0 | 02-28-2004 07:15 AM |
| Headers on 2000 GMC | Maverick | Engine | 3 | 09-21-2003 08:10 PM |
| power window wireing for 1994 gmc sierra | wade coburn | Electrical | 0 | 09-12-2003 02:29 PM |
