Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cant get the ac working after engine install
Old 09-01-2012, 04:14 PM
briansansone's Avatar
briansansone briansansone is offline
4 chevys and a ford
the tube I put in was white. visually it looked the same. its definitely icing on the low side. and it will burn you at the outlet of the evap. I flushed everything except the expansion valve and rear condenser assembly. its ridiculously difficult to disassemble. I even considered bypassing the rear system.
