Can't get axle back in - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2012, 12:46 PM
bbeins's Avatar
Harbormaster
Last journal entry: My 50 Chevy Pickup Project
After replacing bearings and seals in my GM 10bolt 8.5 inch posi, I can't get one axle back in the spider gear. Swapped axles side to side, and still no luck. Pulled carrier out and axles slip in spider gears just fine. Anyone have any advice?
Old 01-25-2012, 01:03 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If everything is in correct all you have to do is stick it in and slightly lift it up and down and while turning it/ wiggling it back and forth and pushing it should fall in. JMO I mean shoot you got one side to go you would think the other side would also.
Cole
Old 01-25-2012, 01:18 PM
bbeins's Avatar
Harbormaster
You would think!
Thanks for reply!
Everything came apart just fine on disassembly. This rear had sat for a long time, so cleaned everything and put in new seals and bearings. I've shook it, beat it with rubber mallett, heck I even stood it on end. Shaft is just to the splines on the spider gear, but won't slip in.
Old 01-25-2012, 01:21 PM
eloc431962's Avatar
Wiki Edits: 37
Have you shined a light up in it and looked at it ? washer might have slipped.
Cole
Old 01-25-2012, 04:05 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
turn the big overhead lights in the shop off (only use a small work light), maybe open a bottle of wine, play some soft rock on the stereo (turned down low)
and trust me, it will slip right in
Old 01-25-2012, 04:14 PM
eloc431962's Avatar
Wiki Edits: 37
HaHaHaaaa!!!!!!!!!!!! cough choke spit ,Thank's Matt, now i have to clean my screen off got Coke the drink all over the place. sometime you crack me up.
Cole
Old 01-25-2012, 05:01 PM
bbeins's Avatar
Harbormaster
Got it!!
Thanks for the suggestion Matt!
But before the wine was chilled a removed the shim/spacer from the bearing on the opposite side. That allowed me a little "wiggle" and I got it in. Put the spacer back in and everything seemd to turn smooth. Guess maybe I'll share the wine with wife who lets me work on this project!
Old 01-25-2012, 05:50 PM
I don't understand?
ah, glad you got it
Old 01-25-2012, 06:27 PM
eloc431962's Avatar
Wiki Edits: 37
Washers shims whatever we call them LOL glad you got it in there. i mean fixed.
Cole
7.5 Axle id and ? about narrowing using ranger axle shafts johnhalabama Transmission - Rearend 4 07-23-2009 05:12 PM
4x4 axle conversion ttb to solid front axle. Jared Transmission - Rearend 6 11-07-2005 08:50 PM
cv axle boots replace or buy new axle? catscan4free Transmission - Rearend 20 03-05-2004 08:25 PM
back agine still spites back throw the barb at low rpm 302truck Engine 9 01-17-2004 10:43 AM
i need to find out the length of my rearend, axle flange to axle flange tony350ss Transmission - Rearend 2 10-03-2002 01:15 PM
