cant get brake drums off! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2004, 07:01 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I just bought a 1967 Rambler Rebel, and I want to take a look at the brakes but can't get any of the drums off (it has drums up front too). They are seized to the hub (in the center). I tried WD-40, propane torch, and a mallet. Any tips/ideas?
Old 09-25-2004, 09:24 PM
poncho62's Avatar
Wiki Edits: 5
Get some better penetrating oil and a bigger hammer. Failing that, you may need more heat........accetelyne.
Old 09-25-2004, 09:40 PM
Old School Nut's Avatar
machinest & A&P Mechanic
Last journal entry: distributer housing...
yeah try a better oil like PB blaster or Kroil.. and take your time to.. let the oils work...
Old 09-26-2004, 11:43 AM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
I usually use some PB blaster and a hammer which I hit the drums with inbetween the wheel studs.
Old 09-27-2004, 08:31 AM
Sandflea427SS's Avatar
Anything with a throttle
does the vehicle run? Loosen the lug nuts (and/or bearing nut for the front, if applicable) just a few turns. Drive a few feet in forward and reverse. The abrupt movements and oil should pop your drums in no time. Start out easy at first and then move on to a harder hit if you don't have any luck right away. Don't loosen the nuts too much. With this procedure, when the drums pop, they really pop. Good luck
Old 09-27-2004, 09:49 AM
malc's Avatar
Living At The Speed Of Life
I think killerformula is an expert on this onehttp://www.hotrodders.com/t36678-15-1.html
Old 09-27-2004, 11:04 PM
Old enough to know better
Kroil and a BFH are my favorite tools.
Remember, as my boss used to say, "Don't force it! Get a bigger hammer."
That sounds funny but big, heavy hammers transmit a good deal of shock and that's what it takes to loosen rust.
