Can't get Holley to idle down with screw - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2010, 05:30 AM
I have a 4100 series vaccumn secondary with electric choke Holley carb on a factory quadrajet intake with a alumiumn adadpter plate to make the holley fit.It is on a 350 chevy in my 67 C-10 truck.I just got it running and i can't get the Holley to idle down.I have the idle screw on the left side of carb.backed all the way out and it still idles too high.I can pull foward on the linkage real hard and it will idle down but this hard pull force can't be corrected with a stronger spring.The 12VDC is not connected to electric choke yet.Also i should know this but which vaccumn port top or bottom does vaccumn advance on distributor usually connect to?
Old 07-10-2010, 05:49 AM
DoubleVision's Avatar
More than likely it has a vacuum leak around the adapter. My best advice is either get a Quadrajet or a aftermarket intake, the best place for a adapter is the trash, they disrupt the vacuum signal and cause the intake to act as if it`s a open plane, each cylinder is pulling off the carbs entire mass which kills low end power in favor of top end power. If you can`t get the throttle to fully return then check the throttle cable, if it`s on disconnect it, if the car idles correctly afterwards then the cable needs adjusted. Either way, I`d still get rid of the adapter.
poncho62's Avatar
Wiki Edits: 5
Is your timing too far advanced?.......Are all the vacuum lines hooked up or capped?
Either of these will cause the high idle
Old 07-10-2010, 06:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Look on the choke side of the carb- the fast idle cam is likely hanging the linkage open too far.
Check to see if the linkage on the driver side is actually contacting the curb idle screw- if it isn't, look on the choke side of the carb for the fast idle cam and move it out of the way to allow the carb to isle down.
AFA the vacuum port to use, this depends on if you want to use manifold or ported vacuum for the vacuum advance. Do a search for the pro's and con's of using either/or.
Old 07-10-2010, 06:15 AM
Theres a hole in the back of the carb (atleast I think it does) and if there is no plug in it then it is a BIG vacuum leak. In later years the trucks brake booster got its vacuum from the back of the carb (or adapter). In earlier years, such as your 67, if they had power brakes at all, they got their vacuum from the back of the intake instead. If you hooked the booster up to the intake and didnt plug the back of the carb then id say thats your issue.
Old 07-10-2010, 07:15 AM
Irelands child's Avatar
All good suggestions above and I'll add one more to look at if everything else checks out and that is with everything disconnected, will the throttle plates completely close. They are connected to the throttle shaft with a couple of brass screws and if it's a new or especially a rebuilt carb, may not close completely. Many years ago I had a brand new 3310 that had that problem. Primaries and secondaries can have this problem
Irelands child
Old 07-10-2010, 07:37 AM
sqzbox's Avatar
My pipes are my music
To answer your question, the port on the primary metering plate on the passenger side it ported/timed vacuum that should have 0 vacuum at idle. Everything else is full time vacuum.
Like colbat says, check the fast idle adj. screw on the passenger side of the carb.
Also, I would look into replacing the intake with an Edelbrock performer intake as you will never reach the full potential of the holley on your engine with the adapter. The adapter was made to install other brands of carburetors on the spredbore intake not for performance. Your engine will probably loose performance over the quad.
Old 07-10-2010, 07:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Only thing, the 4100 doesn't have a metering plate like a 4150/4160.
Old 07-10-2010, 09:54 AM
sqzbox's Avatar
Maybe I ought to just stick with the mouse and keep my fingers off the keyboard. All I do is keep getting myself into trouble.
Man that's one ugly looking holley. Is that just a replacement 4 barrel? I do see the fast idle adj. screw but not the ported vacuum connection. After looking at it I'm even more convinced the fast idle cam is his problem. At least, that's the first thing I would check.
Old 07-10-2010, 10:07 AM
ericnova72's Avatar
More for Less Racer
Pic is of a 4100 Autolite carb, I believe. Could it be that the OP has a 4010 Holley?, which has a fairly similar look. They were discontinued by Holley 10-15 years ago due to poor sales and lack of popularity, and have just been resurrected as the Summit brand carb.
Old 07-10-2010, 10:24 AM
sqzbox's Avatar
Man, I already smashed my other keyboard. Had to drag this old one out of the closet. Please tell me colbalt didn't make a mistake.
Still, no metering block though.
Old 07-10-2010, 01:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
All I have to go by is the OP's statement:
I have a 4100 series vaccumn secondary with electric choke Holley carb...
A lot of guys call the Motorcraft/Autolite carbs a Holley, but if the OP doesn't know what he has or mistyped the numbers, then I don't know.
But either way- no metering blocks.
Old 07-10-2010, 01:35 PM
sqzbox's Avatar
Resurrected by summit might explain why Holley isn't wrote all over it. Never seen a holley not marked! That's wierd.
Old 07-10-2010, 01:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Below is the 4011 (spreadbore):
And the Summit squarebore "new" version of the Holley 4010:
You can see the resemblance to the 4100 shown above in post #8. There are some slight differences between the Holley 4010/4011 and the Summit- the float adjustments are in a slightly different location, and the secondary vacuum can is slightly tilted on the Holley compared to the Summit.
Old 07-10-2010, 02:57 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Yep that 4100 series in post #8 is an Autolite carb, not a Holley.
Another popular misconception is that they're "double-pumpers", but they are not. The diaphragm at the rear controls the opening of the secondary throttles. (i.e. "vacuum secondaries" which are similar in function to Holley)
Ford used them prior to about 1968, and I've had a couple of them myself.
The one pictured is missing it triangular Ford ID tag, but the numbers (i.e. C3AF-R) are also stamped into the edge of the base-plate.
From my understanding, there were two versions of this 4100 series as well, based on venturi diameter.
the 1.08" ones were rated at 480 CFM,
the 1.12" ones were rated at 600 CFM.
More Autolite 4100 info available on Mustang Tek
A couple more things, although it's sort of been dicussed already with the "make sure both primary and secondary throttles can be closed completely" comments.
1.) The secondaries have an adjustment screw under the base plate, and it's a common trick to adjust that to get the primary butterflies positioned over the transfer slots.
2.) Some folks will drill a small hole in each of the primary butterflies for the same reason.
Holley idle circuit baddbob Engine 2 08-19-2007 08:43 AM
Holley idle circuit tuning question curtis73 Engine 25 08-03-2007 01:11 PM
Rich idle on a Holley - what to do? hotrodf1 Engine 11 04-15-2006 11:51 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
How to get Holley to idle down shockers69 Engine 7 01-31-2004 03:18 PM
