Can't get my column out - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2005, 09:42 PM
Stroker56's Avatar
I have been trying to get my steering column out of my 56 Chev sedan and I have unbolted everything I can see fas far as the manual description and Pics show.
Anyone tell me if there is a hidden lock ring or bolt I cannot see down near the box?
Old 02-26-2005, 10:10 AM
abstruse dutch uncle
Most are held to the box thru the ragjoint with a pinchbolt going thru a clamp. Once you take the pinchbolt out, the clamp is still tight, and the rust doesnt help any. I usually pry the clamp open slightly, then can manage to get the joint free with a little persuasion.
Don't know if that helped or not....
Old 02-26-2005, 10:43 AM
Stroker56's Avatar
Thanks for the reply , The shaft looks solid from top to bottom with no rag joint . I am going out to the garage to work on it today and will look again
Old 02-27-2005, 02:29 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
On the '56 the steering shaft is solid from the wheel to inside the steering box.
Old 02-27-2005, 06:21 PM
Stroker56's Avatar
Can't get my colunm out
Ya I found that out this morning .Should be OK if I cut and use a new rag joint or a U -joint with the newer column I will need to look for now. Doesn't matter now I cut it to lift the body off today anyway .
Thanks
GM steering column tilt/wobble repair HELP (pics inside) camaroguy1969 Suspension - Brakes - Steering 18 03-05-2009 01:37 AM
steering column + new wiring stea Suspension - Brakes - Steering 2 12-13-2003 08:08 PM
console column to floor column questions LoudMalibu Interior 1 04-24-2003 07:56 PM
EZ-Wire : Reading Wires From Steering Column horvath Electrical 2 03-23-2003 05:56 AM
shortening the steering column smoran Interior 3 05-02-2002 07:38 PM
